Towing with a 2010 XLT
WEDGE
Kimberley BC Canada
Looking at travel trailers. Wondering how much weight you guys comfortably tow with a 5.4? I know its rated for 9200 lbs ( I've got the HD towing package, auxiliary HD trans cooler and "super engine cooling system")
I just don't want to be anywhere near maxed out. You could say I'm a bit on the cautious side of things. Looking at trailers in the 24-26ft range. Thanks for any advice!
ManUpOrShutUp
PA
9,200 -passengers/cargo in the truck. I've towed 7,000 lbs with 1,600 lbs in the truck without major issues. I was not able to run the AC for most of the trip without the engine temp running away and the trans briefly hit 205F on a steep upgrade, but that was the worst of it. For most of the trip, the trans stayed at 185F or below and engine stayed below 200F.
Blksmk
Canada/USA
I'm in the same position.
Just catching up on maintenance and getting upgrades done.
Only thing left if the 3inch exhaust and a intake/tuner
Adieu
SoCal
That's NOT really how the math works, you were probably about 500 - 700 lbs over rated limits
