CaptOchs
Just curious: When I'm towing a 6500 lb camper, my 2003's MPG averages around 9 MPG. What are people seeing under similar towing circumstances with an Eco boost? Is it about the same or is MPG worse?
I had this same discussion with a co-worker. Ford's F150 has been the sales leader for what, 40 years? Do you think they would put anything in the vehicle that would mess with that status? If so everyone at the top of the company should be fired.
Also Diesels have had turbos for quite sometime. Many go over a million miles. Would you be afraid of buying a truck with a turbo diesel?
Ford has turbos in nearly all of their cars. If they screw it up, Toyota and Honda would be happy to take their customers.
Probably consider it yes if that’s where technology leads us. I’d take it over a 1975 460CI 4V carb Lincoln V8 that made 216 HP@ 4000 /366 TQ @ 2600 ...... those smog years were down right patheticJust curious. Hypothetical question......If they came out with a 1.5 litre that made 375 hp with 400 ft lbs of torque, would the ecoboost fans be on board?
I towed my car on a borrowed trailer last September through some of the Appalachian Mts. And averaged about 12-13 mpg. My car weighs 3800 lbs and guessing the trailer weighed at least 2000 lbs. Mine is an EL with 3.73 HD tow package and the engine only had 800 miles on it then and probably wasn't broken in yetJust curious: When I'm towing a 6500 lb camper, my 2003's MPG averages around 9 MPG. What are people seeing under similar towing circumstances with an Eco boost? Is it about the same or is MPG worse?
Agreed but I think today with the tough EPA and Fuel mileage regulations, Ford is leaning to making small displacement engines with forced induction so the power is there when needed but kinda turned off when not. Hence the name Eco-Boost. They could have gone GM’s route and given us a 4-6-8 V8 which kills cylinders for when the power isn’t needed. From what I’ve seen they are problematic and not as liked as the Ecoboost engines. Just saying coming from a big fire breathing V8 guy , I accept the Turbo V6 trade off.The cubic inch guys and forced induction guys on gasoline motors have argued for decades.... They both have pluses and minuses. Both can be more efficient than the other doing different tasks. Both have come a long way. They both have OHC designs, Variable Cam Timing, Fuel Injection (often DI) etc.... In a way the debate hasn’t changed ground a bit..... it still comes down to more cubic inches or forced induction to achieve more power....It’s whatever you prefer because the reality is they both work.
