brr its cold in here
JUST4FUN
Admin
Moderator Administrator
Il
i did a little fine tuning on my A/C , but not with freon
i used coil klean from a HVAC supplier,its an acid cleaner.
put it in a pump up sprayer and went to town at the car wash on
the condenser.
i did calibrate temp thing in ice water at 33f
tallsville
LA
just4fun i think bh is asking where have you been as in hasn't seen you on here in awhile
panda24619
San Diego
just cause he dont post anything dont mean hes not on. member. hes always watching. haha but dam thats cold!
Newport News, VA
thx TALLS...thats exactly what i was asking...normally you post frequently...maybe cuz the site has become its own...you're chilling now...glad to see you posted something...long time...no read
i'm finally able to do this from work!!! YEAH!!!
walnuts4x4
Watertown, NY
damn that AC looks cold... mine is like crap but I need to replace my blend door.... right now a stick probs the door the right way....
KWT2000
NINE MILE FALLS
thats a good idea as i just got my a/c fixed today... then electric fans to keep it cold around town
JUST4FUN
JUST4FUN
Admin
Il
Sorry Ross i though you were giving me the "where have you been" this is common knowlege stuff :Caffeine:
tmajikman
Cartersville GA
do you spray the front of the condenser, how do you get to it with the grille and bumper in the way, and do you spray it down from the back side (Hose it off)
JUST4FUN
JUST4FUN
Admin
Il
Pulled off the cover off the top of the rad (plastic) , then i sprayed the coil klean on the condensor, as much as i could reach. then i went through the holes in grill
let it sit to do its job (will foam the dirt out) pressure washer: this is important the spray has to be straight into the densor, not on any angle as to bend the fins
tmajikman
Cartersville GA
Thank you sir.
bhamilton
Boston
the condenser.
Nice. Thanks for the info. So where exactly is the condenser located? Behind the main grill, or down below?
Though, I suppose it wouldn't hurt to hit all the radiators with this stuff, would it?
Expeditionary
Tampa, Florida
i dont want to sound like an idiot but where is the condensor located in relation to the radiator, power steering collar, tranny fluid cooler, etc. ?
Also all you did was clean it with a pressure washer and it made your air cooler???
