Window Trim
BakerEdition
EF Chaplain
I have this trim rubber trim on every side...being this was a California truck it is sun beat. I have tried everything from back to black to wipe new and nothing seems to make this look any better. I thought I saw a picture on here somewhere that someone had some chrome covers or overlay they used....I want to keep it black, but dont want to replace these as it is just a cosmetic issue...they are rubber so paint is really not an option. any thoughts??
FordandPolaris
Saint Cloud, MN
Lots of people have plasti-dipped them. Its not a perfect black like the paint you have, but it will look better than the current state. Mine are the same way. The plasti-dip will hold onto the rubber fine.
BakerEdition
BakerEdition
EF Chaplain
did you do yours? did you have to take them off? got any pictures...plastic dip...I have hear allot about this...is that the stuff in a spray can you see on TV.
BakerEdition
BakerEdition
EF Chaplain
is it a spray can or do you dip it...I have no experience with this stuff...HELP!
Hampton, VA
i dont think u can do anything for it...i've noticed that too...dont think anything can be done outside of new door
BakerEdition
BakerEdition
EF Chaplain
its a trim piece that the body shop took off for painting...dont need a new door..the door is fine..
FordandPolaris
Saint Cloud, MN
Its a spray can, basically a spray paint. It is used to coat tool handles (and now truck rims) with a rubber coating. Home Depot, Lowes, pretty much anyone with a large spray paint section carries it. It works very well for this kind of application. All of my door trim, mirror caps, rims, and bumpers are covered with it.
I use a pressure washer to wash the truck too, no problems.
BakerEdition
BakerEdition
EF Chaplain
can you send me a couple of pics of your window trim...maybe I will go to the pull a part and get one of these pieces and give it a try...see if i like the look...im kinda **** about that after a 4k paint job...
FordandPolaris
Saint Cloud, MN
I forgot to mention why plasti-dip is so cool. If you do not like it, it will peel off in one piece. That makes it sound weak, but it really isn't.
Plasti-dip + clear coat:
This is a good one. I have NOT done the window pieces you are referring to. You can see they look crappy. The plasti-dip is on the chrome door accents below and the mirror caps (also chrome). Nice flat black:
