Keep the air ride suspension. You can replace the entire system, airbag's, front shock's, compressor etc. for just a bit over what a conversion will cost. I've found the entire kit for $680.00. If you do convert, the Expedition will sag with a load and you will miss the air ride.
how about no.... a conversion kit is $200 and its really dumb to take the time to replace the system when coils work just as well.
I tow a 5000lb boat with my truck and yeah the rear sags a little bit but I wouldnt trade sagging with a load for sagging all the time with a POS air suspension... Not to mention If you ever do any kind of offroading it sucks to have air suspension because it tries to level the truck when off camber.
How many threads did you post about fixing your air suspension problems?
Most of us dont want to go through that when there is a more reliable, cheaper, and EASIER way to go.
monroe part numbers 90006, 90010, 90005
4wd, 4wd, 2wd. respectively
