Rear-break, Hazard, and turn signals not working
RRANDAL
Hello all,
Vehicle - 2007 Expo limited, EL.
My rear break lights, rear hazards, and rear turn signals are out. Strange thing is my tail lights work at night but no break lights. All front lights work and the third break light up top works just fine. I replaced the multi-function switch /arm on the steering column and no luck. Any thoughts anyone?
Thermo
technical advisor
RRANDAL, I have seen something like this in the past and you are looking at pretty much 1 thing that can be causing this. You need to replace your hazzard switch.
JUST4FUN
Admin
Moderator Administrator
Il
multi-function switch has the sw in it OP replaced it
R
RRANDAL
Oh ok, yeah I replaced it already and that didn't fix the problem. Would the switch at the break pedal affect the hazard and turn signals?
Big White
Upstate NY
Not the turn signal switch, but the emergency HAZZARD blinkers switch.
Thermo
technical advisor
The button that you push to activate the hazzard lights, that is the button I am talking about. I am not sure where it is located on your 2007 truck, but on my 97 it is located on top of the steering column all by itself.
JUST4FUN
Admin
Il
the hazzard sw is in the multi sw its all the same sw
mjelen
colorado
Hey I have a question. My 2006 Expedition, the right rear brake and light bulb is not working. I changed the bulb still not working. When I turn the blinker on to the right, I get a fast blink from the instrument cluster. What can I look for? The truck has not been abused or in any accidents. I baby this thing and now the darn light doesn't work. Please Help Me.....
stamp11127
Temple, Georgia
Mjelen, helping you will depend on your skills and tools available. With lighting problems I start with grounds, then check for power at various locations. You can start at the source or at the end of the circuit.
Do you have a test light or dvm?
Newport News, VA
my wiring harness went bad in mine on the driver side that cause this to happen back in 2009
Big White
Upstate NY
Wiring harness is a pretty big thing. In fact, it is the largest component of any car. Where about the wiring harness did it go bad? By the switch, by a tail light light, somewhere in the middle? Thanks.
