Well I dont know about fuel economy but alcohol is like a solvent I dont know how that will gunk up your engine. And if it burns like shit then why do people that race switch to e85. Im not saying im gunna race the expy or nothing like that.
Because E85 is 105 octane and around $3 a gallon. Race gas is $10 a gallon. Most of the guys I know running E85 say the motors are cleaner internally. But I've seen some issues with the E85 gunking up the fuel pumps and filter. It's this black stuff that dissolves with gas.
Personally I wouldn't run E85. But then there isn't a station close to my house.
The issue is the junk that was previously in the tank. The ethanol then dissolves the junk and it tries to go through the filters. The ethanol doesn't cause the crud, but it causes it to be carried out of the tank.
I've run thousands of miles on E85 in my van. When I first started I had to change a filter after a couple of months. Since that point, no problems whatsoever. When winter hits and the price spread gets funky, I make sure that my wife uses quality fuel rather than whatever crap is cheapest. But we do burn at least 10% ethanol all the time. So there is some cleaning properties happening constantly.
The fuel lines are different, the pump internals are different, the injectors are different, and you lose 40-50% MPG. I've also heard the octane is inconsistent at the pump, racers buy gas from well known companies that mix their own or stand behind the quality.
E85 is a more corrosive fuel and can wreak havoc on a non e85 fuel system. I wouldn't run that stuff unless I had a true e85 compatible vehicle and it was 50% less than regular gas.
Just admit it.
Ok, I'm calling B.S. Your probably wanting to do hot laps at the local track.Just admit it.
Sent from my Galaxy SIII Using Tapatalk2
Do you know where I can find parts numbers for the E-85 compatible parts??
You realistically lose at most 25% mpg as long as the tune on the ECU is correct. The 40-50% number is an old study done by a college paid for by oil companies. Octane is controlled by the same EPA rules as other fuels. There is a seasonable adjustment for cold weather. This will take the concentration down to 70% ethanol in the fall but back to 85% in the summer months. The exact date depends on the local climate.
Pricing can be a difficult issue though. I live in hotbed of ethanol production and use. We can see price spreads over $1 during the summer driving season, when the summer fuel blends are being used. But I have seen some locations that have a negative pricing spread during the low winter months.
The rule of thumb for my wife is... If its a 50 cent price difference.. get the e85.
