oem entertainment problems
sand man
grand forks,nd
can anyone me with a problem I have with the entertainment center in my expedition? it is an oem rear ceiling mounted unit. some how 2 dvd's were inserted in the unit at the same time. 1 came out with the eject button but the other one will not come out. every time the car is started it cycles a few times trying to eject it I assume but it will not come out. I tried to pull the fuse and recycle it that way but that didn't work. TIA for any help you can offer
Newport News, VA
welcome to the site...not sure if you'll get a lot of responses as it seems you only joined to get help with your situation...there are some on here that dont like when ppl do this...it happens all the time...so be aware if you no one answers...all i can say is it will need to be opened to get it out
S
sand man
grand forks,nd
Am sure you are right about just asking for help...but I thought I would try. Tried searching for the answer first but couldn't find what I was looking for. I am curious as to how the unit is mounted...all I can find is 4 screws where the monitor folds up to.
jjbusa
miami
What year do u have I have an 04 and it's mounted with 4 screws when the tv is open. Then I think held in place with clips all u have to do is pull dwn. Then u will see the dvd player and 4 more screws to open the cap of the dvd player should be able to manually eject.
S
sand man
grand forks,nd
Thanks, it is a 2007 and those 4 screws you mention are the only ones i see too so I thought they might be the ones but didnt know if there was others i didnt see. I think i will try and remove those screws and see it it comes lose as you described. Thanks again.
RI-Matt
Rhode Island
Here you go.
Matt
