5.4 Motor rebuild help.
Fanatic1074
Nashville
Hello all. I am looking for some experienced input. I am going to rebuild my 5.4 in my 03 Expy. I need some help finding good prices on an engine kit (gaskets bearings etc.) I found one on Autozones site but i was hoping to try to find a cheaper option. Also their kit includes pistons. I doubt ill need them.
Also i was thinking about doing additional head work beyond valve job. Can someone provide input on what i need to tell the machine shop to do? I have never done anything like this. Im hoping to get more power kinda like the PI heads on the newer motors. Do i just have them mill the heads? If so how much? Also I am told that the block will support the additional compression up to 11.5:1, Can anyone confirm.
Thanks.
tonydiv
technical advisor
Middle River, MD
Might I suggest going this route instead. Just bolt it in and go.
Ford 8 Cylinder Engines
If you still want to go the diy route, I'd suggest having someone with some engine building experience help you. It's not as easy as it looks on the Poweblock shows.
You also don't want to pick up the cheapest gasket and seal set you can find. That is actually the place where you spend a few extra bucks to insure reliability.
Check with Summit Racing and Jegs, their tech people are very knowledgeable. They can get you everything you need.
Fanatic1074
Fanatic1074
Nashville
I have actually rebuilt a few engines before (chevy 350 and 454 and couple others) and i will have a buddy that's done some before with me helping.
By cheaper i ment cheaper as in cost, not cheaper products. For instance Head gasket set on Autozone (felpro) is 199 but only 130 through amazon. Same product just cheaper on web.
I dont want to spend over 2k on a new engine when i can possibly rebuild this one for 700ish and a couple weekends of my time.
I guess what i really wanted was someone to tell me, what i can do to get the best power increase w/o having spend a ton of money. I would like to end up with 350+ RW HP and 450+ RW torque, i dont think thats too far off considering with my low compression (Average of 90 over the 8 cylinders) i just dyno'd the truck and it came in at 240 / 313.
Ill check those two places for input as well, but it just seems like i have better luck on forums.
Thanks guys.
01yellerCobra
San Diego
For the 4V heads the big thing seems to be opening up the valve seats. I think the magic number is 90% of the valve size. It's been a while since I looked into head work though. However, if you don't have PI heads I would find a set to freshen up. They're a lot better then the NPI heads.
It's not the compression that kills the block, it's a rod coming apart and putting a nice window in the side. I doubt you'll get to the point of testing the block's durability. Do you ever tow with the truck?
Fanatic1074
Fanatic1074
Nashville
Yes alot. This is why i want more power. I tow alot.
mc0311grunt
victorville
Look up mannys hardcore performance. He does wonders with lightning. For the power levels you want you are going to have to spend more than you think. Unless you find a supercharger setup you're going toneed more than just some head work
Fanatic1074
Fanatic1074
Nashville
What about a place to order parts. Anyone know a good place?
Sent from my SCH-I535 using Tapatalk 2
01yellerCobra
San Diego
The reason I was asking is because the compression you're shooting for. Personally I would run a little lower compression because of the extra load from towing.
Misspelling brought to you by Tapatalk
Fanatic1074
Fanatic1074
Nashville
What's a good compression number to shoot for then?
toms89
technical advisor
MD
The higher the compression the more likely you get detonation. Odds are also highest at peak torque and higher loads. Towing increases the load greatly.. This is why I believe trucks generally run lower compression. You can bleed off some of your effective compression with more overlap in the cam but this will lose low end torque which is counter productive in a truck.
Getting the numbers your looking for are optimistic with out a serious complete system redesign or build. Compression, cams, heads, intake, exhaust, Gear ratio and tune to take advantage of higher rpms necessary to make the power.
Better airflow will always help to a degree but beyond that you need an increase in displacement, higher rpms or forced induction. The 5.4's biggest limitation as far as making power is the heads/ valve size. This is due to the relatively small bore vs stroke.
Running premium will allow more compression but it will then be required fuel. I cannot give you a number though... will have to research it.
Expy530
Redding California
I seen you are planning on spending around $700ish. With that budget you won't get any extra power. Parts for this engine are not cheap like 350 or 454. Just keep it stock. If u do go big on it and add bunch of HP you will end up ruining the tranny. If you tow a lot try changing diff gear ratio. Anyways just my opinion I've have rebuilt these engines before
Fanatic1074
Fanatic1074
Nashville
OK well I'll prolly just try to find out if I have the pi heads and if not buy those and rebuilt them. Anyone got any tips on figuring out if u have pi heads?
I have heard that they should bolt right on and provide more power w/o increasing compression a ton.
Sound like a good idea? Or should I just rebuilt my stock ones and call it good?
BTW I already have a lot done to this truck. CAI, exhaust, 75mm tb, tb spacer, accell coils, custom tune his SCT tuner.
Sent from my Verizon Galaxy S3 via tapatalk
toms89
technical advisor
MD
03 has PI heads. Started using them in 99 till they went to 3v heads.
Fanatic1074
Fanatic1074
Nashville
I think I have decided on just replacing pistons. However Im having trouble finding a good set for a reasonable price. Anyone have any suggestions?
Lightnig
Behind you
What do you consider 'reasonable'?
$50-60 ea for a OEM replacement piston sounds about right to me...
Fanatic1074
Fanatic1074
Nashville
I can get OEM pistons for around 275-300 full set. Reasonable to me would be 400 or less. Maybe I'm just cheap tho. I seen a set but they were 850.
No members online now.
Landsbutter
