Supercharger choice
Stoned06
Milwaukee
Kenne Bell is another one that owners of Ford modular engines like to use.
Well Freeway, you beat me to it.....sort of! lol.
toms89
technical advisor
MD
Supercharger selection for the 1st and 2nd gen 2V expeditions is very limited. I believe you can still get a procharger centi blower or do a lightning conversion. Kenne bell and whipple have several blowers available if you already have the lightning supporting hardware.
Feel free to post links of available blowers for sale that work with the 2v mod motors but don't think you will find much. Many kits have long since been discontinued.
http://www.andysautosport.com/ford/1997_2002_expedition/performance/supercharger_kits/procharger/
TRTLSLO
Kalamazoo, MI
Try the guys at torktech.com They were my choice when I had an explorer. Totaled the truck just before blower shipped so not sure how install would have went :(
TactialMonkey
TactialMonkey
Washington
I need to get the lighting stuff like throttle bodies and stuff but I'm going to cam it and change the valve springs then do the supercharger I know whilpple makes the charger and all I need to do is bolt it on to the rest of the lightning stuff I just don't know what I kneed other then the charger like intake manifold and other stuff. Any help would be awesome!! I'm going to get my long travel before the supercharger hahaha each are 4 grand
Stoned06
Milwaukee
Madenterprise.com has everything you need to do a NA to a S/C conversion. Here is his list on his website. I take that back, it looks as if some things are no longer available (NLA).
Bracket with idlers and special bolts NLA
Tensioner Assembly Available
Lightning Alternator (outright, no core return) Available
Alternator Stabilizer Bracket NLA
Intercooler Pump and Pigtail (Bracket NLA) In stock
Intercooler Reservoir with Cap NLA
IAC Tube Available
Throttle Cable In stock
Throttle Cable Bracket In stock
Cruise Control Cable NLA
IAT Sensor (fits in air cleaner) Available
Water Pump Spacer Available
PCV Tube (left hand side) Available
TB to MAF Rubber Connector with clamps Available
90mm MAF Available
Intake Gasket Set Available
In-Tank Fuel Pump In stock
Upper Radiator Hose Available
Upper Two Intercooler Hoses NLA
Original Equipment Installation Bolts Available
Drive Pulley with Belt (Boost level of your choice)
toms89
technical advisor
MD
IAC Tube Available
90mm MAF Available
That's assuming you already have a complete lightning upper supercharger assembly plus heat exchanger. It is detailed on his site in the link you provided. When I did my setup I purchased all the misc items necessary to complete the swap through Mike @ maddenterprise.com. Great guy.
You will need to search ads and purchase a complete as possible lightning upper supercharger assembly. They are getting harder to come by. Expect to pay about $1,200 for a used set up depending on how complete it is then add to it the cost of items listed above. You may find it very difficult to purchase a set up minus the eaton blower and if someone was willing too, doubt very much they would take much off of the purchase price.
If you go this route it will take some time, money, research and patience to gather all the parts necessary. Or some Luck!! :)
Included photos of my upper supercharger assembly. Then I still needed most of the supporting hardware mike has listed.
Basically the kenne bell and whipples available for the lightning setup just replace the supercharger itself and intake plenum between the throttle body and supercharger.
TactialMonkey
TactialMonkey
Washington
so if I just walked up to a lightning and took the charger off set it aside and grabbed all the other things like throttle body intake mani and misc wires and hoses then bought the whipple bolt on would that work in a perfect theory?
