Plastidip Project Done! Almost murdered. Lights, Trim and Wheels
rock3ralex
Pomona, CA
Finally got around to finishing the plastidip project. Took the lights off the roof. Swapped grills, dipped the trim, did the headlights and wheels.
A tip for the lights is 18 min in the oven at 250F. Then use a utility knife to cut the seal. Makes getting into them so much easier. Then reseal with outdoor silicon. Be generous and you'll have nice blacked headlight.
Took about 6 cans total for everything. Not a bad $40 investment.
Sent from my DROID RAZR HD using Tapatalk 4
Newport News, VA
ive heard as high as 350-400 degrees for 5-10 mins to open the lights...suppose to pull right apart
bcmaxx
trail,b.c.
LOOKS GOOD, BUT......Who Balanced your wheels? why are the weights opposing each other like that? We have been doing tires 12+ years and I've never seen that, thats all
FordandPolaris
Saint Cloud, MN
My tires have the same thing. I tried balancing them several times in high school, and they would not work any other way. I blamed the bigger tires.
tallsville
LA
looks good. let me know when you are back up here and we can go get the expy dirty
R
rock3ralex
Pomona, CA
I thought about going higher in temp, but I worried about smoking some of the coatings on the wires. Besides, 250 gets that headlight pretty hot to to touch. I wonder if 350 would have been easier.
Any reason you skipped the wheel weights?
I had smaller tires on their before and had dipped the wheels with the weights on it. Then after I got the larger tires, they put newer weights on that weren't the old dipped ones.
I'm planning on just touching them up in a few days.
I believe that just has to do with the larger tires. Not all of the silver marks you see are weights. Some of the silver marks are un-dipped parts of the wheel from where weights used to be.
Definitely amigo! I'll be back up in about a month. Maybe a little less depending on the weekends.
KWT2000
NINE MILE FALLS
as for balancing i started using air bb's works great and they are always balanced
just thought i would throw it out their
R
rock3ralex
Pomona, CA
airsoft bb's, for like toy guns. I run a half can in each tire on my jeep, weld on beadlocks make them near impossible to balance conventionally. They work great!!
I've never heard of that before. Very cool! :favorites37:
carlos08
Fl
That's a stealth Expy! Are you planning to tint the tail lights?
