Rear springs...Overload, leveling, etc
Buck Nasty
Oregon
Hey gang. I'm thinking about getting a rear hitch motorcycle carrier for my Ex. With the carrier, my motorcycle and gear...we're talking an extra 500lb on the rear of this thing. As it is, she already sits a little low in the rear.
Does anyone have any recommendations for a stiffer spring or maybe a rear leveling kit to compensate for extra sag?
'98 XLT....Coil springs.
Thanks in advance!
Grasshopper
Moore, OK
Why does it sit low in the rear?
I wouldn't think that just having a bike carrier would sag it very much at all.
wrangler45337
Pitsburg and Greenville, Ohio
Your best bet is to buy some good rear shocks or air adjustable shocks. I know there are alot of companies like Fabtech that make a coil spring for them, but then you will be raising it 4-6 inches in the rear only. You may be able to find some spring spacers to put under the coils to give you just alittle more lift, but not sure if anyone makes one that is specific to the Expy's. It sounds to me like your rear shocks are old since you said the back is sagging already. Bilstein makes some Heavy Duty Rear Monotube Shocks for the '98 2 or 4 wheel drive. They aren't air adjustable but I have used them before and love them. They are more than able to handle the 500+ lbs you are looking at hauling. I know Summit Racing sells them for $69.95 a piece. Hope this will help you out.
B
Buck Nasty
Oregon
Originally posted by wrangler45337
Your best bet is to buy some good air adjustable shocks. I know there are alot of companies like Fabtech that make a coil spring for them, but then you will be raising it 4-6 inches in the rear only. You may be able to find some spring sapcers to put under the coils to give you just alittle more lift, but not sure if anyone makes one that is specific to the Expy's. It sounds to me like your rear shocks are old since you said the back is sagging already. Bilstein makes some Heavy Duty Rear Monotube Shocks for the '98 2 or 4 wheel drive. They should be able to handle 500+ lbs. you are looking at hauling.I know Summit Racing sells them for $69.95 a piece. Hope this will help you out.
Thanks for the tip Wrangler. I'm sure she's due for new shocks anyway. I was hoping to find either a small spacer or a stronger spring.
GRIP
hoboken,nj
well if it is saging in the rear the spring need to be changed not just the shocks. the shocks don't hold up the truck the spring do.if you just change the stocks you will blow them out in a couple of thousand miles. change the spring and shocks.
AvroAero
Toronto, Ontario
Mine sags in the back because of regular heavy loading. I put airlift bags in the rear. Cost 70 bucks and work well. Super smooth when loaded and pressurized right.
B
Buck Nasty
Oregon
Avro...Where did you get the bags and did you install yourself? Easy?
AvroAero
Toronto, Ontario
Jcwhitney. Installed myself. Kind of easy, the bags are a bit stiff to ram into the coils. The first one I pull the coil out and stuck it in easy but the other side had a vacume line on the axle I didn't want to stretch so I just rammed it in there.
Won't raise the height though because the bags are short, which kind of sucked because I was looking for a bit of a raise. I could jack the pressure but it becomes pretty damn hard unloaded. Really helps with body roll to, especially if you jack the pressure.
huklebuk
Jacksonville, NC
I have the air bags in the springs as well. Makes a huge difference when I tow my boat. I put the onboard air compresser and gauge in mine so I can control it from the drivers seat. Took me most of the day but it wasn't hard, just tedious. I think they work great.
