Projector Halo Foglight?
4x4Dude
Scottsdale AZ
Well i'll repost this thread what i just posted over on the f150 forums.
I just recently purchased the Halo Projector headlights
http://cgi.ebay.com/ebaymotors/99-0...007QQitemZ170196344776QQrdZ1QQsspagenameZWDVW
It looked like it was a simple install, the bracket looks like the same as my stock one, but when i took out the old fog light and went to go install the new ones...it seems like the projector is to big to fit int he stock hole that is cut in the bumper. Has anyone else out there bought these and maybe had to cut the bumper to make room for the headlight? Just looking for some advice before i go crazy with my dremel lol Thanks for any help guys!
MadTxn
Stupid question... did you try installing them from both the front & the back?
I haven't tried it, but I'm looking at those myself.
4x4Dude
Scottsdale AZ
what do you mean from the front and the back? they only fit in one way, and you have to access it from behind the bumper. it comes assembled in one whole piece bracket and all.
I'm dying to get these things installed cause i think they would look so bad ass!!! and i've never seen an expo or even an f150 with these on before
AvroAero
Toronto, Ontario
How much are you saying? Like just a little bit on the top will be okay but anything more than that is a bit excessive.
MadTxn
Can you take a picture showing where it's too big? From a picture on ebay I saw, you *might* be able to take the projector apart to separate the front form the back, install the back, then reinstall the front. Hope that makes sense...
4x4Dude
Scottsdale AZ
Raptor....when you installed them did you have to cut in to your bumper at all or did they fit right in?
MadTxn
Those aren't bad... what's the beam pattern like?
Raptor424
Woodbridge, VA
no not at all...perfect fit for a 2003-2006
will get a better DAY pic of the lights
Raptor424
Woodbridge, VA
Originally posted by MadTxn
Those aren't bad... what's the beam pattern like? [/QUOTE
THE FOG BEAM IS REALLY GOOD, AND BRIGHTER THAN STOCK..IM REAL HAPPY WITH THEM...NOW I JUST NEED TO ADJUST MY HEADLIGHT BEAM, AND THEN THEY WILL BE PERFECT
[/IMG]
[/IMG]
MadTxn
If you don't know how to adjust those headlights, I recently found out that the stock alignment bolt does nothing. You have to turn the ones sticking straight out from the back of each projector. The low beams have two on the bottom (they also adjust them left & right) and the high beams only have one. I'm just waiting for some warmer temps to get out there at night and aim.
