Expedition907
Size of ballast...buy a kit from ebay like zentec...9006 and 9145 for fogs...
I know the sockets, what is the canceller and relay?
relay is used if for whatever reason you don't get enough power to both lights...it'll push the power to both lights...and the canceller helps with flickering of the HID bulbs...u only see that if youre on a wall...u cant see it on the road unless it just ridiculously bad...I have a relay on mine but mine are 85w so they need more power
No...u don't need it...more than likely u will get 35w and ur good to go
so if I were to get 9145 these would be able to just plug and play into the stock socket right? same with the regular 9005 and 9006 sockets with out any relays or cancellers?
In hopes of clarifying things. 35w refers to the power of the lamp, 6k and 8k refers to the color temp of the light (4k yellowish - like halogens, 5k is white, 6k white with slight blue, 8k bluer, etc.). As long as you keep the power factor at 55w or below you will not need the relays and other stuff. Does that make sense?
I have ordered the 6K from hidsrus.com, got 6k's all around hi/low/fogs. right now they are being shipped. hope they turn out awesome
907 tell me bout your viper remote start... not full alarm? I want it... thanks.
