rob21
I have searched this topic and have not found exactly what im looking for. I had a gear swap done and should have had them replace the bearings while they were in there since they have to pull the axle out anyway. Anyways, im chasing a washboard like rumble at highway speeds. between 55 and 70mph i have this faint washboard like effect while going down the highway, and ive narrowed it to either rear wheel bearings, or U-joints. Tires are new and i have ruled out the torque converter. It does it when i let off the gas pedal and shift into neutral, so i dont believe its the engine shuddering. What are some symptoms of a wheel bearing going bad? U-Joint? What are some checks I can do to either diagnose it as being the problem or rule it out? Anything else im missing? I know it is not the rear gears, as it was doing this before the gear swap. Does the driveshaft have weights somewhere I can check also?
