motorized passenger ann driver windows not responsding to adjuster switch
Beardskii
Ar
The switch moves, the mirrors do not. I beleive i found the right fuse. no burnt out plug. I just want them to work :/
B
bedrck46
kindly provide more information year? model? do you have memory mirrors? Just telling that the switch moves but the mirrors don't gives some but not all information needed
B
Beardskii
Ar
00 epxedition xlt. Doubt it has memory mirrors. could never confirm because they didn't work from jump street.
B
bedrck46
ok if you had memory mirrors there would be a switch or the drivers door but its part of the memory seats circuit
If you can check the mirror switch on the door check the orange/light green wire to ground to see if you have 12V that will tell you if you have power to the switch
you could manually move the mirrors to get them set to where you want them until we can try to figure out your problem
Copper93
Charlotte, NC
Try cleaning the switch. The switch gets dirty and won't make contact. For both mirrors to go out and the fuse being good, that is where I would look. I've had them gum up and had to spray them down with contact cleaner before.
B
Beardskii
Ar
Just got back in time to read up on your suggestions. Do I have to remove the door panel to get to that switch or can I pop that switch out from the molding?
B
bedrck46
you most likely will have to remove the door panel to get to the switch The way it is mounted, it is very tight to try to reach in to press the tab that holds it in place. I would first try to spray some cleaner around the rocker switch and if that doesn't help then remove the panel to get to the switch
