Superduty Axle swap
TactialMonkey
Washington
I wanna run a Dana 60 front end on leaf springs and a Sterling 10.5" rear end on leaf spring too and a ZF5 manual transmisson any ideas to a transfer case setup could i just use a BW 4406 manual shift or do I need a heavier t case with the larger axles. Thanks Guys!
toms89
technical advisor
MD
Why?? Are you planning to build a monster truck with an aggressive lift??
FordandPolaris
Saint Cloud, MN
Samrider777 did something like that, but his truck is huge and I would imagine not very practical for a daily driver. What do you plan to gain from the solid axle swap that the IFS does not give you?
TactialMonkey
TactialMonkey
Washington
I want a leaf spring lift and the manual locking front hubs so I and eventually get a DOHC 5.4 with a supercharger I want to have the deep gears and wider axles for the look I like and caus its more solid than ifs
toms89
technical advisor
MD
Sounds like you have major plans for your expy!
You really need to speak with samrider because as far as I know he is the only one here that has done a leaf spring conversion with the front suspension.
TactialMonkey
TactialMonkey
Washington
sam rider and southern expy both did a leaf spring swap..... im hopefully going to get plate steel soon but havent been able to find anything local thats not dimond plate i have been hunting craigslist fot 1/4" plate steel to make my bumpers for months and still no luck... i have to make frame mounts aswell if anyone knows of a sturdy design for a bumper mount i want bolt on to the frame but welded through the bumper to a shackle on the front so i will be able to recover expy by herself in the woods
