I need a little bit of help from some of the Alarm and Remote Start Masters around this forum, I'd really appreciate it! Might even help others
I recently bought a 1997 Ford Expedition Eddie Bauer 5.4L and want to put an alarm in it so I bought an AutoPage C3+RS730LDC 4-Channel 5+Button Chrome LCD Alarm with Remote Car Stater. The Expedition already has an aftermarket remote start installed in it that I plan to remove to use this new system.
I have installed many stereos but never an alarm and when I saw all of the wires this thing comes with, I realized I might have a problem. Considered paying someone else to do it but nobody is willing to so I’m sticking with the original plan of doing it myself but need help as to which wires go where.
Any and all Help would be great!
Heres what I’ve got so far, PLEASE correct me if i have something wrong and help me with the wires i don’t know. My connection choice or question will be after each —>
6 PIN HEAVY GAUGE WIRING CONNECTIONS:
*Violet Wire—Starter Output—> Red/Light Blue(+) wire at Ignition Switch Harness
*Red Wire (2) — +12V Power Input—> Yellow(+) and Light Green/Purple(+) wires at Ignition switch harness
*Yellow Wire – Ignition 1 Output—> Blue/Light Green(+) wire at Ignition switch harness
*PINK Wire – Ignition 2 Output—> Red/Black(+) wire at Ignition switch harness
*Brown Wire –Accessory Output(Heater /AC Output)—> Gray/Yellow(+) wire OR Black/Light Green(+) Wire at Ignition switch harness????? There are two wires but the Autopage system only asks for one so which one do i use?
5 PIN WIRE HARNESS:
*RED / WHITE WIRE –PARKING LIGHT RELAY INPUT ——> do nothing with
*WHITE WIRE — PARKING LIGHT RELAY OUTPUT—> Brown(+) wire at the Headlight switch
*BLACK WIRE — SYSTEM GROUND ---> Ground to Chassis
*BROWN WIRE – (+) 2A SIREN OUTPUT –—> Red wire on Siren
*RED WIRE — SYSTEM POWER (+12V CONSTANT) — —> Yellow(+) wire at Ignition switch harness
3 PIN DOOR LOCK CONNECTOR:
*GREEN WIRE - (-)Lock Pulse (+) Unlock Pulse —> ???
*RED WIRE - Not Used —> ???
*BLUE WIRE - (-)Unlock Pulse (+) Lock Pulse —> ???
20 PIN WIRE CONNECTORS:
*H6/1 BROWN/BLACK WIRE: 200 mA (-) Ground Output When Running—> Ground to Chassis?
*H6/2 GRAY/BLACK WIRE: 200 mA (-) Second Starter Output.—> Not Used
*H6/3 PINK WIRE – (-) 200mA Programmable Output—> ???
*H6/4 WHITE / BLUE WIRE – (-) Instant Start & Turn Off Input–—> ???
*H6/5 WHITE WIRE – (-) 200mA Dome Light Control Output –—> Black/Light Blue wire in passenger kick panel
*H6/6 BROWN / WHITE WIRE – (-) 200mA Programmable Output Horn Output – —> Dark Blue wire in steering column harness
*H6/7 BLACK/GREEN WIRE – (-) 200mA Channel 4—> ???
*H6/8 BLACK/WHITE WIRE – (-) Neutral Safety Switch Input or (-) Enable Switch Input –—> Ground to Chassis?
* H6/9 ORANGE/WHITE WIRE – 200mA Grounded Output when Disarmed - N.O. Disable—> Ground to Chassis?
*H6/10 WHITE/RED WIRE - Tachometer Signal Connector ——> Not Used
*H6/11 BLUE/BLACK WIRE – (-) 200mA Accessory 2 Output –—> Ground to Chassis?
* H6/12 WHITE/GREEN WIRE – (-) Diesel Wait To Start Input—> Not Used
* H6/13 YELLOW WIRE – (-) 200mA Ignition 3 Output –—> Not Used
* H6/14 GREEN WIRE – Negative Door Switch Sensing Input (Zone 3) ——> ???
* H6/15 GRAY WIRE – (-) 200mA Channel 3 Output –—> Not Used
* H6/16 BLUE WIRE – Ground Instant Trigger Input (Zone 2) –—> Ground to Chassis?
* H6/17 WHITE/VIOLET WIRE – Positive Safety Shut Down Input –—> Light Green wire at switch above break pedal
*H6/18 VIOLET WIRE – Positive Door Switch Sensing Input (Zone 3)–—> ???
* H6/19 WHITE/BLACK WIRE – Negative Safety Shut Down Input – Hood trigger Input—> Connect to Hood Trigger provided
*H6/20 ORANGE WIRE – (-) 200mA Grounded Output When Armed –—> Ground to Chassis?
Here is the link to the install manual: http://remotelystartedmn.com/admin_files/PDF/C3-RS-730install1.pdf
5 PIN WIRE HARNESS:
