Expy/lightning issues - Round 2
toms89
technical advisor
MD
After I washed my Expedition yesterday took it for a drive to dry it off. Not particularly hard on it and it just began rapping loudly. Pulling in the driveway, open the hood and it sounds like its coming from the drivers side valve cover area at the front. My guess would be a bad lash adjuster?? introducing way too much slope in the valve train. But not ruling out rod knock or broken wrist pin after researching the lightning forums.
I did notice when I would pass anything on my left recently I would here some ticking reflected off the various objects but was not noticeable other wise. One of those "is that my vehicle?"
Took a video this morning upon cold start and you could not really hear anything until it is revved up some. Still cold so not nearly as loud as when fully warmed up.
https://www.youtube.com/watch?v=VoocRUgzsHw
Thoughts??
nonwoven29
Carsom city Nevada
Tom,
That sucks buddy. I think from the vid it sounds more like the LA. It just dosent have that rod knock sound to it.
Found this vid. I know it's a 3v but boy it sounds similar to your sound. I know if it were me I would be a little upset.
I know in my 99 exp when could she makes a similar sound could and is gone before full warm up.
Low oil pressure at some point?
http://m.youtube.com/watch?autoplay=1&v=GxVC09Wl6Iw
toms89
toms89
technical advisor
MD
Oil pressure has been good.
Definitely sounds like a lash adjuster to me at this point due to the location of the sound. But the odd thing is it worse when its warmed up. When it is cold there is no noise. I think of "lifters" as bleeding down when shut off and do not like to pump back up. This seems to be the opposite the case.
Lash adjuster is relatively easy to deal with but the circumstance seems odd to me.
toms89
toms89
technical advisor
MD
Anything beyond the lash adjuster and I will obviously be pulling the motor... :(
CaperCanadian
Alberta, Canada
Tom, might sound a little left of center, but mine was doing the same thing, started taping just like that, and thought it was a cam follower. It was a bad #7 plug. Before pulling her moter out check the plugs, never know might be worth a try.
toms89
toms89
technical advisor
MD
Is this leading into another April fools joke like last year???
I wish but it's not April 1st this time.
Time to start looking for a new daily driver! Cannot afford the downtime of pulling the motor to repair.
toms89
toms89
technical advisor
MD
Yep.... convinced its time to take on a car payment. It has been quite some time but might save enough in fuel to help pay for much of it. Been averaging a little under 12mpg with the Expy.
nonwoven29
Carsom city Nevada
Maybe so. You can tinker with the expo at your own pace and have some coin back in your
pocket with a fuel sipper.
I bought a used focus wagon last year for this very same reason.
FordandPolaris
Saint Cloud, MN
That's a bummer... Hopefully the fix is fairly straight-forward. I am looking at the same plan when my motor goes out. Buy a cheap truck and rebuild her at my own pace. Hopefully you don't have to pull it out of the truck though.
toms89
toms89
technical advisor
MD
Crazy busy at work so have not had time to mess with the expy. :(
But the good news is $$ is coming in so it will help. Think I will get another driver so I can take my time with it if it ends up being more than a lash adjuster.
If I end up having to pull the motor I would like to go through it, take my time and make appropriate changes/mods where need be. :)
splintrcel
Milwaukee
Having a back up car is always the best. Everytime i work on my truck i am missing some part or need some odd tool so i have to run and get it.
tallsville
LA
Ive always had a 2nd car. Always felt weird not having a 2nd vehicle, so i just picked up a 99 civic for a commuter. And it sucks being so low compared to the expy
toms89
toms89
technical advisor
MD
Update!
Well... do have back up vehicle now. :)
Did some extensive listening to the tick and cannot easily pinpoint it. My best guess is it is coming from the #5 exhaust valve. Before I start pulling it apart called my original tuner to have a look. JJ with Woodbine Motorsports! Figure he has much more experience trouble shooting issues such as this.
On my drive up I realized it only does it while the engine is under zero load. Sounded fine driving there till I would stop at a light then you could hear it slightly. In neutral it gets worse. Now confident it is not in the bottom end. Rods, bearings, wrist pin, etc.... should be ok.
I get there and he listens for a few minutes from different angles and reving it up. His first impression is bad valve guide... :( He said he can't rule out rocker or possibly lash adjuster but does not believe they are responsible. His impression is the valve is floating around with no load but as soon as load is introduced it helps line it up.
It all makes sense to me because on cold start there is no noise and the noise does not appear until she is warmed up. Typically lash adjusters or lifters make noise upon cold start as they bleed down when they sit. And I would expect a rocker to get worse with load...
Have to pull valve cover just to be certain but if rocker and lash adjuster look fine I will pulling the motor and have the heads freshened up and possibly larger exhaust valves installed. Maybe some mild porting but the tfs heads ports are pretty good from the factory.
metaldrgn
somewhere
What I would do is disconnect fuel and spark from each cylinder on the drivers side one at a time and see if you can isolate it to a particular cylinder. If it doesn't go away odds are it's a lash adjuster or something else. I've seen random posts about the timing chain slapping the guide which is a possibility.
Spare cars are nice to have for situations like that. They can also help break up the monotony of always driving one car.
toms89
toms89
technical advisor
MD
I have disconnected injector from the misc cylinders on that side. No change.
I listen with a mechanics stethoscope at all areas for signs of timing chain tensioner/guides failure, lash adjuster, rocker arm, flexplate, rods, etc.... I really could not pinpoint it to any one item. It is most pronounced when I listen to the #5 primary on the headers. This leads me to believe the #5 exhaust valve is having issues.
I have TFS heads and believe others may have had issues before with the powdered metal valve guides that they come with stock. Many say they are too brittle for performance applications and bronze guides should be installed. I dunno... may soon find out.
metaldrgn
somewhere
What about disconnecting them on the other side just to see if there's any change? I'm having a similar issue on my 02 Tahoe and I just changed all the lifters and still have that noise above 1800 rpms. I'm kicking myself for not checking the piston for play because I had the head off, but I didn't think of it till after. I'm just going to pull the pan and see if hopefully one of the bearings needs replacing or connecting rod needs new bolts and I don't have to pull the engine. Also I heard it loudest on the #1 cylinder which is #5 for Ford.
metaldrgn
somewhere
So I tried disconnecting fuel from each cylinder on my Tahoe and I still had the tick. I took off the intake valve rocker arm(I think it's the intake valve) prior to all this and the tick went away so I'm confused because I've already changed the lifters (lash adjusters on yours). Maybe a bent valve? I also swapped rocker arms with no change. I don't know how it would just happen but I bought it this way so I don't know what the history on it is.
Have you done anything more with yours?
toms89
toms89
technical advisor
MD
No. Have not had time. Believe it is bad valve guide. May pull valve cover just to verify its not a rocker or lash adjuster. If not will pull motor and go through it. Have heads sent to machine shop for new valve guides and likely have larger exhaust valves installed. If it comes out I plan to take my time and do some modifications I have been considering.
No members online now.
Landsbutter
