PATS advice
RevHeat
San Antonio
I have an 2000 that currently has 294,500 miles on it. It still runs perfect, only when I can get it started. I cannot start it due to the PATS system malfunctioning. When I try to start it, the Alarm light flashes.
What options do I have? At this point in time, I am trying to get it to last another 10k miles, but do not want to put a lot of money into it. Is the dealer the only that can fix this issue?
Thanks,
Rev
Snapshot
Kentucky
Are you using the factory keys for the vehicle? Does any of the keys have a crack in them? Or do you have any kind of remote start installed in it?
RevHeat
RevHeat
San Antonio
I am using factory keys and neither one is cracked. No remote start installed and have never made any modifications or added another alarm system.
toms89
technical advisor
MD
I believe your best option to get the pats fixed is unfortunately the dealer.
You can turn off the pats as well as the cel trigger it would set via a custom tune. I personally have done this but had the tuner already as well as the ability to tune it. But in your situations this would likely be a more expensive solution than the dealer to repair pats so whats the point?
B
bedrck46
You could also take it to a locksmith that does automotive systems and have him program new keys You can also buy uncut keys on e-bay and have them cut then programed. One thing that could cause a problem is if the transmitter that is located around the Ign is cracked or damaged
tojohnso
A woman I work with had this problem with her '00 or '01 Expy. It turned out to be her key. I'd go that route first. Do you have both keys? Does one work better than the other? If so, then it may be the key(s).
B
bedrck46
The following was copied from the service manual
1) No communication with the module — instrument cluster
CJB Fuses:
Fuse 2 (5A).
Fuse 6 (5A).
Fuse 30 (30A).
Circuitry.
Instrument Cluster.
GO to Pinpoint Test A .
2) The anti-theft indicator is never on — no three second theft indicator prove out
Instrument cluster.
Theft indicator.
GO to Pinpoint Test B .
3)The vehicle does not start — theft indicator proves out for three seconds as normal
Less than two keys programmed to the system.
Transceiver not connected/defective.
Circuitry.
Transceiver internal antenna damaged.
Non-PATS key, damaged key or no code received.
Partial key read of PATS key.
Unprogrammed PATS key.
CARRY OUT the instrument cluster On-Demand Self-Test. RETRIEVE DTCs. If DTCs are present, GO to Instrument Cluster Diagnostic Trouble Code (DTC) Index. If no DTCs are retrieved, CHECK for other possible no-start causes.
No powertrain control module (PCM) ID stored in PATS.
PATS/PCM ID do not match.
Problem with Standard Corporate Protocol (SCP) communication network.
CLEAR the stored DTCs. CYCLE the ignition key from OFF to RUN. RETRIEVE continuous DTCs. If DTCs are present, GO to Instrument Cluster Diagnostics Trouble Code (DTC) Index. If no DTCs are retrieved, CHECK for other possible causes.
4)The anti-theft system does not operate correctly — the vehicle starts but flashes a fault code on theft indicator at key ON
Incorrect PCM calibration
GO to Pinpoint Test K .
RevHeat
RevHeat
San Antonio
If it is the key, would the Alarm indicator continue to flash (even with key not in the ignition) until it accepts the key? I ask because both my keys are in good shape.
B
bedrck46
the system will flash at a slow rate when no key is in the Ign. If it flashes at a rapid rate when you try to start then there is a problem. There is a transmitter that is around the lock cylinder that could be cracked and that would cause a problem also the chip in the instrument cluster could be bad or the PCM isn't get the correct information
RevHeat
RevHeat
San Antonio
Yes, it is doing the rapid rate flash when I try to start it. I will look at the transmitter.
Thanks everyone for your help so far!
Rev
RevHeat
RevHeat
San Antonio
For future reference, I took it to the dealer. The PATS problem turned out to be a burned out relay. The dealership claimed it could have been caused by the worn out terminals on my battery. As such, they replaced the relay and terminals. Total amount was $230.
Thanks everyone for your help!
Rev
kwyorman
Jackson, GA
Rev! Which relay was it? I'm having a no start problem right now that I believe is caused by the PATS. It just started out of the blue and I've changed everything that could have caused it. Please, please PLEASE let me know ASAP.
I would love you forever!
tojohnso
Worn out battery terminals? That doesn't make sense to me. The battery would wear out before the terminals would. Was it the cables? Did they explain how that could wear out the relay?
Glad you got it fixed. Really strange resolution though.
BAD RONALD
Fairfield CT
... PATS problem turned out to be a burned out relay. The dealership claimed it could have been caused by the worn out terminals on my battery. As such, they replaced the relay and terminals.
The wording of the "resolution" is a bit strange. He says the dealer told him he had worn out terminals on his battery. So...they replaced the terminals? Probably meant the battery cable terminals with broken , frayed or loose (not worn) wire. Makes me wonder what he meant by "relay"...
RevHeat
RevHeat
San Antonio
Sorry for the confusion guys. I was trying to post to fast yesterday. It was the PCM relay that was faulty and the battery terminal clamps were bad.
B
bedrck46
if you look at the wiring diagram for the pats system there is no relay in that circuit. But being the Pats send a signal to the PCM if the PCM relay was bad that would cause a no start problem
