Rear air/heat not working
pavaojc
2000 XLT 4X4, 5.4
The controls on the dash work perfect, the ones overhead for the middle seat row also work fine. The ones for the third row seat vents, it's like it's not even plugged in. No fan. Does anyone know what could be causing this?
Thanks,
John
pavaojc
pavaojc
Haha, that's a great story. One day I wasn't thinking about what I was doing and I grabbed it thinking maybe I could break it free. Instead I broke it off. My daughter had a good laugh!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
B
bedrck46
it always nice to hear an update on problems I wish more would do it
B
bedrck46
would suggest you get a copy of;
Ford workshop manual on DVD. Can be obtained from seller "morpheousking" on e-bay. Cost about $15.00 Much better than Clymer, Haynes or Chilton and also includes wiring diagrams
Don't waste your money on a Clymer, Haynes or Chilton Manual.
It is well worth the $15.00 just make sure you get the DVD for your year as the seller has different DVD's for different years
It will aid you in making repairs and help improve your troubleshooting skills
splintrcel
Milwaukee
So are any of the vents blowing air in the rear. If none of them are blowing air its most likely the blower motor. It is really easy to get access to the rear aux AC unit so take the panels off and play with the controls to see if anything is moving and see via multimeter if the blower is getting some electricity.
pavaojc
pavaojc
Bedrck46 - thanks, I'll check that out.
Splintrcel - the vents to the middle row seats work fine. The ones to the third row of seats its like the controls aren't connected. Tonight I'm going to see if they're even lit up when the lights are on, I didn't think to check.
Sent from my BNTV600 using Tapatalk
pavaojc
pavaojc
The controls light up when the lights are on. Where is the rear aux AC unit? Does it maybe have it's own fuse I should check?
B
bedrck46
Again suggest the above It will answer many of your questions
B
bedrck46
The auxiliary blower motor does not operate correctly
Circuitry short/open.
Function selector switch.
Front/rear auxiliary blower motor switch.
Auxiliary blower motor resistor.
Auxiliary blower motor relay
The auxiliary blower motor does not operate using the rear auxiliary blower motor switch
Rear auxiliary blower motor switch.
pavaojc
pavaojc
Are any of the other controls able to run the rear fan?
What other controls would run the rear fan? My understanding is that the ones in the dash run the one in the front, the ones over the rear view mirror run the one in the center and the ones over the center seat run the one in the back. Am I wrong?
Thanks,
John
pavaojc
pavaojc
This, right? Thanks again!
2000 2001 2002 Ford Expedition Factory Service and Repair Manual | eBay
