Radio static when rear defrost is on.
Boose
2017 Platinum EL
NJ
Has anyone ever experienced radio static when the rear defrost is turned on? REAL annoying, My rear defrost elements are all fine, no scratches. When the defrost is off, no static... There is supposedly some antenna amplifier up in the headliner...? Has anyone ever had this problem?
0627Devildog
NY
I have not had any problems with the rear defroster causing issues, but I DEFINITELY had a bad/loose connection somewhere that drops in and out when I hit bumps in the road.
The rear passenger side window holds the antenna and the connection to the ant is above the headliner right at the window. There has been a loose connection that drops the am/fm stations for the last 25K miles or so. I believe that the connection is bad where the wired connections makes the transition to the window connection.
It is in such a funky place I am not sure how to address. Can this be repaired without replacing the whole rear window? Is the headliner removed easily?
Boose
Boose
2017 Platinum EL
NJ
The antenna lead definitely goes to the unit I'm speaking to which is supposedly tucked up above the headliner... I haven't attempted to try to pull it down yet. Is you connection at the window good as far as you can tell?
stamp11127
Temple, Georgia
You may be experiencing noise on the power line to the radio. Search online for car audio noise filters. Or you have a bad connection somewhere that is arching and the radio antenna is picking it up.
Boose
Boose
2017 Platinum EL
NJ
my problem is directly related to the rear defrost circuit as the sound is crystal clear as long as the defrost is off. I don't see how the 2 could be connected.
stamp11127
Temple, Georgia
Think about it, what do radios do? Receive signals. Only two ways for that to happen, interference through the power leads (they also act as antennas) or through the antenna itself. There is something on that circuit that is giving a signal that the radio is picking up.
0627Devildog
NY
Bad ground on either the radio, or rear defroster maybe?
0627Devildog
NY
My connection to the actual window itself is definitely what the cause of MY issue is. . . . The connection from the ant. cable to the connector that leads to the window is solid. But where that connector transitions from cable to the connection inside the window is weak.
I just have no idea how to fix it because of the ****** spot it's in.
0627Devildog
NY
Ford Dealer?
I brought it there 3 times for the same issue when it was under warranty. Mysteriously, while it was under warranty. . . . they could NEVER seem to replicate the issue, even though it did it on the way there AND on the way home.
RAWPWR
nh
can you make the static happen while not driving? so actually make it happen in the driveway with the defrost on and then not happen in the driveway with the defront off?
Boose
Boose
2017 Platinum EL
NJ
It's not consistent unfortunately. I am going to try to test this with a wet vs. dry lift gate glass. I have a feeling it has something to do with the power draw of the defrost. When I try it now when it is warmer out, I did not get any static. Over the winter, when using the defrost to actually clear up the rear glass, the static was all the time.
B
bedrck46
Just a thought.
When you used the rear defrost did all the grid lines look as though there were working? If they all were not defrosting there is a break in one or more of the grid lines and it could be possible that it was arcing across the break causing the interference with the radio.
Boose
Boose
2017 Platinum EL
NJ
To be honest with you I never got around to actually validating each line was conducting. On appearance, I never saw any blatant gaps in the heating elements. I am going to scope the lines with my multimeter for consistent voltage & resistance. Great recommendation, Thanks!
FordCustSrvc
Dearborn, MI
Boose and 0627Devildog,
Happy Friday to the both of you! Since your vehicles are out of the new-vehicle limited warranty, and has no recalls, or Customer Satisfaction Programs, it’s recommended that the vehicle be brought in to your dealer and speak to your service manager about the concern.
He is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed.
Also, Please check here to see recalls notices. All you need to do is plug in your VIN. =)
You can schedule an appointment online here.
Since it’s not always consistent try to get the vehicles in to the dealer right away when they're actively experiences these symptoms.
I hope this was helpful and have a great weekend! :happy107:
Tricia
DmanNC
NC
I have the same issue with static with the rear defrost on. I have found out that my rear glass leaks also, maybe it is related???
JUST4FUN
Admin
Moderator Administrator
Il
0627Devildog
NY
Tricia
Hey Tricia,
While I certainly appreciate the insight. . . . .Considering I brought it in 3 times while under warranty, none of which found the issue, I am not sure another trip back to the dealer is the remedy I'm looking for.
JM
04SVT
tx
Is there some kind of grounding issue with the defroster that's causing the radio to go nuts??
FordCustSrvc
Dearborn, MI
Hey Tricia,
JM
0627Devildog,
I understand. I’ll be glad to document your dealer feedback. Please PM the following: details of your experience, your full name, VIN, dealer, and best contact number. I’ll make sure it’s noted.
Also, feel free to reach out to me if you have any questions/concerns in the future. :smile:
Tricia
