2011 Remote Start
Drth Vdr
Thanks Guys, just did this to my '14 EL Limited this morning. Mine was installed at the factory and was taped in a bundle, basically behind the panel where the power pedals switch is. Had to remove both the panels in order to access.
Bigdaddi
Illinois
Is it possible to purchase the remote system at the dealer and install myself?? I've done this in the past with a remote keyless entry on a 2002 Ram P/U.
David1
Pa
Just installed the 100 series remote start on a 2010 w/sync. Everything worked fine until I changed option 7 now I get 4 beeps which means tach not programmed. I switched option 7 back and unplugged entire system no change. Any ideas ?
steveg_nh
Southern NH
Bank 2, option 1 (tach mode) needs to be set to Tachless (the LED should be ON). I'm guessing you held the button too long to change the MYKEY/key in setting, and reset the system to defaults again, in which case tach mode is set to OFF right now.
David1
Pa
OK, I did reset all to the default settings per the "option programming chart" I have. However, it shows Learn Tach as Bank 1 option 1 (LED boxes are blank) and Bank 2 option 1 shows "Blind Crank" with default as ON.
Also,
Last night while trying to teach tach, I now get no response when pressing the remote and the pats seems to not learn remote ie security light never goes solid for 3-5sec. The trucks battery was low enough to not start and need a jump, so I am hoping that is why the learn feature stop working.
Thanks for your time.
David
steveg_nh
Southern NH
Also,
David
But you have to set bank 2 option 1 to tachless, then bank 1 option 1 doesn't matter. Is that how it's set? "Blink Crank" sounds the same as tachless, but sounds like your system might be a bit different than what we are all used to seeing here for a series 100. Here's what I have on programming options....
  • RemoteStartProgramming_options only.pdf
David1
Pa
Wording is similar. Your pdf closely matches my page 9 the PEPS instructions, mine are page 1 for the 100 series.
bank2 opt1 "Blind Crank" default is "ON" but bank2 opt4 "1press to start" default is "OFF" possibly this should be on ? I can't seem to get a PDF under 100KB but did a gif ?
steveg_nh
Southern NH
Something is different about that kit, vs what I have and what most are talking about in this thread. It only goes up to the 2010 model year, vs 11+. I thought they were the same up to 14 so not sure what's different.
this is how all of my settings are, if it helps...see attached.
  • Remote Start Information.txt
expresspedition
