2006 5.4L Expedition
xspiritdannyx
Illinois
Hi all and Merry Christmas,
I'm have a slight issue with my 06 expedition 5.4L. There seems to be some misfires, only when the engine is under load (when going up hill with low revs). The misfires ONLY occur when the RPM is under around 1500 RPM and under load. It's getting to the point I have to push the accelerator to downshift to get the misfires to go away, or the engine stutters too much under load.
I have around 128k on the truck and everything is perfectly fine except for this misfire problem.
Could anyone point me in the right direction in identifying the problem or a possible fix?
Thanks very much,
Danny
JUST4FUN
Admin
Moderator Administrator
Il
Time for a tune up plugs and coils ,is the ses light on
X
xspiritdannyx
Illinois
There has been no CEL light. I'll try replacing the plugs and coils and see if that fixes it up. Thanks for the reply!
rwing21
Louisville
Keep us posted please. Thanks!
My 04 is getting coils and plugs real soon. Hoping to see some additional pickup and would be great to see 1 MPG back!
thebuckaman
il
I am getting them done on my 04 tomorrow. Slightly rough idle and hoping for a mpg increase as well
Stanger4Life
W
Sounds like a tune up for sure! Spark plugs wires/coils. Also a good time to change your fuel filter and run some fuel system cleaner. The sooner you get this done the better!
AbelNavyvet
Weslaco
6K when you do the 100K tune up what do you or anyone on this forum do? please tell me if I am missing something.
1.Plugs
2.Coils
3.Oil well when you need to replace it of course
I mean what else is there that needs replacing? Is there a sensor that I need to replace?
Stanger4Life
W
1.Plugs
2.Coils
Well, it really depends on what has been done recently. Maybe between 80-100k miles.
Sensors don't really have a life span, they just will fail, luckily most of these will come with a check engine light.
Plugs
Wires/Coils (if you feel this is neccessary to replace)
Fuel Filter
Air Filter
Brakes and Rotors
Inspect ALL fluids if any shows signs of dirty, flush and refill.
Inspect and replace all belts if neccessary
Inspect for any leaks, worn out bushings, seals etc.
Test Battery and Alternator (usually want to do around winter as well)
****The One People usually don't do****CHANGE OUT TIMING BELT
Check Compression
Other than that, just the little stuff like check tire pressure, do you need alignment, light bulbs, A/C working, everything else working like it should that needs attention.
My rule of thumb is, treat your vehicle at 100K miles as if it were a brand new car. If you take a relatively small amount of time to go over it all, your vehicle will go another 100K miles with typical maintenance with the exception of maybe a transmission. 100K miles doesn't mean it's done for, it just means more things should be replaced to bring it back to life. It's really true, the better you care for your car the longer it will seem like a new car.
2005exp
eastbay
Timing belt?
Haha!!!
Also need to flush out transfer case n rear diff. Power steering fluids, and brake fluids for sure. Back flush heater core and replace coolant.
Check brake lines (rubber) for signs of cracks. Check and repair any and all leaks. refresh all rubber seals around doors, sun roofs, ETC....
tsingson
NC
I'm in for plugs. I used to get the misfire when trying to accelerate. Changed them all out and the truck has been running like a champ ever since.
AbelNavyvet
Weslaco
how do you guys prevent the engine coils from burning out? mine keep burning out every 8 to 10 months. when it rains its even worse. when it rains down here in south Texas my coils burn out....
X
xspiritdannyx
Illinois
Hi all, sorry for the super late response, but I ended replacing the cp's and the spark plugs as per suggestion and it fixed all of the problems I've been having. The spark plugs were a MAJOR PITA to do, 7 out of the 8 broke requiring the leslie tool. Another unrelated problem arose a day after I replaced the CP and the spark plugs. The engine would dangerously just shut off in the middle of the road and the dashboard message showed "engine fail safe mode" or something. Turns out it was the throttle body. I just took it to a shop for this job and they ended up replacing the whole throttle body which fixed the problem. It was a dangerous experience having the engine just shut off in the middle of the road losing power steering. Ford should definitely redesign their fail safe parameters to not have the engine randomly shut off in the middle of the road for something like this.
Newport News, VA
ur the only one ive heard on here with this prob...buy OEM parts and see what that does
AbelNavyvet
Weslaco
6K they are OEM parts they are the OEM coils you would get at Advance auto parts...
its every time it rains or I drive thru a puddle one coil burns out and they are random ones. it always happens.
