You dont need to remove any bolts getting the stock grille off. The grille is held in by clips all you have to do is gently pull or grab a flathead screwdriver and gently pry it off. If you are **** like me, i removed the entire grille support section which is all bolted down and some screws are hidden behind the headlights so those have to come off too. All that just so i can line up the aftermarket grille and drill the holes for the rivets to hold it in place nice and straight.
thread resurrected
for the 98-02 Expy, I can take off and put on the factory grille without taking off the whole front fascia?
