1998 expediton EB stalls and cuts off
sonmisojos
NC
I have a 98 expedition EB and it drives fine but if you have to come to a Quick stop it will cut off if you don't press on the gas. It will Also cut off if you are driving and you put it in reverse. Once you turn it back on it goes in reverse with no problem. Any idea what this could be? I have changed the air filter and cleaned the carberator and nothing helped.
ICrushedAPrius
New Jersey
I bet anything its your Idle Air Control (IAC) they are notorious for this. What does your truck idle at (RPM's) when you stop at normal speed and sit there for a bit? If it isnt 800-1000, you want to get it checked out.
Firepuppy
Rome NY
2002 door lock gem
Can i get a used remote door lock module from a junk yard and replace mine in my 2002 expedition? Is it a plug and play??
Thanks
Bedrck47
Elizebethtown, PA
Thanks
You need to start a new thread for your problem as it isn't related to this old thread dealing with stalling and cutting off
