grasshopprdisco
2008 EL...transmission is "shuddering" intermittently while driving. I know it needs fluid and filter change.
I'm probably going to hear crap on this one, but you don't do a filter/ fluid swap to fix an automatic transmission problem. How many miles on your vehicle? If transmission fluid is burnt, draining and refilling makes shift and noise problems worse. You will need to diagnose your problem first.
Wow, I would have never believed old trans fluid could cause these issues. But three of you had amazing results. Good to hear, just a fluid swap out could fix your issue, but glad it did. Thanks for the update.
Grasshopper fixed his problem with the fluid/ filter change. Read post 13. It still amazes me that it works. For those of you with the 3rd gen vehicles, be sure to change fluid on schedule or even a little early.
I just had a safety inspection performed on a new (to me) 2009 Expedition EB 4x2. It drives fine now at just miles short of 130k miles... he told me to avoid doing any flush or transmission maintenance unless there were previous records of prior maintenance. He explained it will just loosen up the varnish in the transmission and cause failure...Was experiencing the shuddering when around 35-50 mph. Swapped out my transmission fluid (didn't change the filter) and it completely went away. It's been around 10,000 miles since I did that, still no issues. My truck was around 155,000 miles when I did the swap.
Worth mentioning that before I swapped the transmission fluid the shuddering would go away completely if I switched off OVERDRIVE (button on the shifting knob).
After reading this thread... I may go back on his recommendation. Power flush or just drain, filter, and fill?
Sent from my SM-T813 using Tapatalk
