Only bottom half of cooled seats working...?
Yoop33
St. Orlampawaterton Islands, Florida
Anyone else experience this and know a fix?
I use the cooled seats every day and seems like only the bottom portion is cooling and not the top.
I've experienece the entire system not working in previous trucks but not only half the seat.
Any ideas?
powerboatr
North East Texas
Was it working before
If you unzip the seat cover on the back side
You can get to the foam ducting
Carefully blow it out
Low pressure air. Remove filter first .
It's usually the small holes get clogged with gunk from clothing
jeff kushner
North of Annapolis
I think to add to that....there is a section in the owners manual about replacing the seat filter. I'm guessing there is some ductwork as PB describes. Is it really foam duct? Regardless, look for any break in the duct because air will flow though the easiest path so if there is any break, seal it because it will pour out there instead of being forced through the high-static(resistance) of the small holes in the seat covers.
jeff
powerboatr
North East Texas
yep its a molded channel in the foam,
plus a few small hose sections.
f150 2015 and 16 had a tsb on the same issue, i assume our seats are 99% same same
and running the seat at middle speeds seems to work better, maybe because of saturation of cold air, vice flowing through at higher speed
Yoop33
Yoop33
Just played with it a bit and seems almost too simple to do a decent job. The air just doesn't seem to have enough pressure to begin with and isn't as cold as I'd like, but then there is a gap between the duct and the seat so unless you're sitting in the seat and applying pressure to push the back against the duct, no air will come thru the seat... which I guess is the point but doesn't really allow you to cool the seat before sitting in it which I'd like to do on some days.
Also, there seems to only be two 1/4 inch holes from the duct thru the form and to the leather that ALL the air is expected to pass thru and then be distributed thru the whole back rest of the seat. Just doesn't seem efficient.
If there was more pressure and it was colder it would probably be fine. But right now I can't feel it much at all.
I'll have to look for the filters and consider changing those
powerboatr
North East Texas
super charge the fan....:driver:
John Christopher
CT
Any ideas?
I was wondering if you were able to fix the issue with your seats. I'm having the same problem with a 2013 Navigator. Thanks
powerboatr
North East Texas
i went out and looked at mine and clean the filters....neither side had the filter like both my f150's did.....my book even says there is a FILTER to be changed periodically...kind of hard with no filters.
I need to go see the dealer now
ExpeditionAndy
Fort Wayne, Indiana
My 05 had 4" square by 1/2" pleated filters like in a home A/C system. They were like $40 each at the dealer. I took mine out and checked them and they looked like they were new.
ExpeditionAndy
Fort Wayne, Indiana
andy yours are installed from factory
i thought it was odd mine were missing
That was on the 05 when I was having issues getting the seats to heat or cool. I was surprised the the filters looked like they were new. I had to raise the seat has high as it would go and move it as far forward as I could get it and I still had to use a mirror to find them.
