Tail Lights
mdntblu
Corona, CA USA
mdntblu
mdntblu
Corona, CA USA
2013
2016
They look the same. Kinda weird that all the websites make 2014-2017 seem like different ones.
gixer2000
Retrofit or Bust
Massachusetts
They could be different. Keep in mind how much the electronics have changed and how many things have been added to the CanBus network. Yes even bulb wiring/sockets are different for any bulb that is can monitored. Ill look into the difference and report back
gixer2000
Retrofit or Bust
Massachusetts
Looks like only the front bulb has changed for the 15/16. The rear remains the same so I would imagine the manufacturer for the led tails just hasnt updated it yet. Front and rear fitment posted below. Dimensions for the tails alone should be good
mdntblu
mdntblu
Corona, CA USA
It's kinda random that not a single website or Amazon listing or eBay Listing says that 14-17 will work with the 07-12 tail lights.
I even emailed a few eBay sellers and they replied and said they will not work on a 16. Thoughts?
Flexpedition
midwest
The Ford part number has not changed. 07-17. Passenger side is 7L1Z13404AA, the partslink number FO2801201.
The interchange guide shows 166 variants:
Ford Expedition 4WD Eddie Bauer 2007, 2008, 2009, 2010
Ford Expedition 4WD EL Eddie Bauer 2007, 2008, 2009, 2010
Ford Expedition 4WD EL King Ranch 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition 4WD EL Limited 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition 4WD EL Platinum 2015, 2016
Ford Expedition 4WD EL XL 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition 4WD EL XLT 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition 4WD Funkmaster Flex Edition 2008
Ford Expedition 4WD King Ranch 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition 4WD Limited 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition 4WD Platinum 2015, 2016
Ford Expedition 4WD XL 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition 4WD XLT 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD Eddie Bauer 2007, 2008, 2009, 2010
Ford Expedition RWD EL Eddie Bauer 2007, 2008, 2009, 2010
Ford Expedition RWD EL King Ranch 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD EL Limited 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD EL Platinum 2015, 2016
Ford Expedition RWD EL XL 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD EL XLT 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD Funkmaster Flex Edition 2008
Ford Expedition RWD King Ranch 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD Limited 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD Platinum 2015, 2016
Ford Expedition RWD XL 2011, 2012, 2013, 2014, 2015, 2016
Ford Expedition RWD XLT 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
ExpeditionAndy
Fort Wayne, Indiana
I've been looking at the LED tail lights but honestly what I don't like about them is the LED panels don't look like they provide much side view. They seem too close to the back of the lens to give any side view light. The installation instructions say that you use your bulb sockets and connect them to the tail light pigtails that they provide. It essentially looks the the end of the bulb with wires going into the tail lights to power the LEDs, you still have to use your incandescent backup bulb.
I'm seriously considering just replacing the bulbs with LEDs but I am concerned about getting the hyperflashing issue. I know that you can change the flasher unit but I haven't figured out what I need if any.
gixer2000
Retrofit or Bust
Massachusetts
I've been looking at the LED tail lights but honestly what I don't like about them is the LED panels don't look like the provide much side view, they seem too close to the back of the lens. The installation instructions say that you use your bulb sockets and connect them to the taillight pigtails that they provide. It essentially looks the the end of the bulb with wires going into the tail lights to power the LEDs, you still have to use your incandescent backup bulb.
Check out diode dynamics if you do decide to go with bulbs. I'm actually thinking about building my own led panels to retro into these but haven't had much time to get stock together.
Sent from my LG-G6 using Tapatalk
Jefes_Shyt
