LED plate lights - such a difference
ExpeditionAndy
Fort Wayne, Indiana
PS - Beautiful White Expedition - Expeditionandy. I have the same white with the gold panels below. I love the white on these trucks.
Thanks! I have really come to like it. I am a nut about having my truck clean so I am always taking it to the car wash to get dirt off. We have a car wash company that gives you unlimited washes if you pay monthly, so I go through at least once or twice a week. :)
Dani Vela
Corcoran, CA
I changed out my puddle lights and plate lights to LED as well as my brake turn signal rear lights as well. Very happy with them. Also changed out my headlight assemblies on my 03 Expedition. I have attached a photo of the front.
Kingfamilyexpy
Tn
Love the halos what grill did you get and how much was it i was lookong for one before but black with the emblem place in the middle
RedExpy
Kansas
JDM ASTAR 10pcs Super Bright 194 168 175 2825 T10 PX Chipsets LED Bulbs,Xenon White
resurrecting to make sure i understand.... these JDM bulbs will replace my inside lights and license plate lights with no issues? save... getting the old ones out...correct??
going to order led's to replace lights and want to make sure I understand...
gixer2000
Retrofit or Bust
Massachusetts
I feel like with the projector Style backup bulbs you would get more coverage because not only do you have the projector but you also have LEDs around the circumference of the bulb. The bulbs around the circumference with Luminate into the reflector like the factory bulbs did what the projector would also get you some distance behind you
A
Adieu
SoCal
3rd gen? Yeah
Just will need a plastic trim prybar to safely open up the interior lights.
2017-06-07 22.25.25.jpg 2017-06-07 22.25.46.jpg 2017-06-07 22.26.21.jpg 2017-06-07 22.26.47.jpg 2017-06-07 22.27.05.jpg
And a push fastener puller and a replacement pair of fasteners for the rear license plate
PS there is NO need to yank out any modules from the car, I just had a spare overhead thingie laying around in the garage after an interior swap and used it to demonstrate. Normally just pop off the plastic button/lens thing and swap it right on the ceiling
RedExpy
Kansas
awesome!!!!! thanks for the input guys!!!! ordering now... delayed as i got busy with life but will have this done... thanks again....
RedExpy
Kansas
ok..changed the 4 lights and damn that's a huge difference.... the cargo area led light didn't come in the pack so i need to get that... how do you get to the bulbs for the license plate... and which trim retainer clips do i need for replacement?
ExpeditionAndy
Fort Wayne, Indiana
There is a little tab on the right hand side of the bulb holder, you push it to the left and use a nylon pry bar to wiggle it out.
Be careful because the tabs get brittle and can break easily. Both of the tabs on my 17 broke the first time that I took them off and they were brand new. If you look at the right side you can see the notch in the face where the tab goes.
RedExpy
Kansas
Thanks all..... got mine related on the license plate..... so.. my next and final question (let's be honest there will be others) is does the 3rd Gen lights (tsil, back up, side marker) if replaced with l.e.d.s require canbus bulbs...if I am even saying that right...
Suoerbrightled.Com has both but wasn't sure if it needs those types...
ExpeditionAndy
Fort Wayne, Indiana
What I found out is, you only need resistors for the front turn signals, you can replace the rear turn signals without getting the hyper flash. You can have the dealer turn off the bulb out hyper flash warning feature and then you don't need to worry about canbus LEDs. I am not sure if the Canbus LEDs have the resistors built in, but if they do then you should be able to use them and not worry about it. But I'd ask that question before I buy them.
A
Adieu
SoCal
Not sure which push fastener it was, just that it had the little popup thingie in the middle...I got a kit for Fords on Amazon, also had the pull tool, and I used it for a few other things as well already:
https://www.amazon.com/gp/aw/d/B01IYXD68W/ref=yo_ii_img?ie=UTF8&psc=1
Cargo area ones worked, don't remember why I ordered the 5pack though -- think I mistakenly THOUGHT it would also work for something else:
https://www.amazon.com/gp/aw/d/B0177C3AZ0/ref=yo_ii_img?ie=UTF8&psc=1
A
Adieu
SoCal
15-17 have a different plate light assembly AFAIR
A
Adieu
SoCal
Also a 15-17 thing, earlier 3rd gen gers hyper flash from rear turn signals
