2015 expedition driver door won't unlock
chris bauer
las vegas
Hey everyone, so having a unlocking problem on the driver door only. Obvious I can unlock it manually. I have pulled the door regulator out and tried the tinfoil fix. Nothing has changed. I manually ran the motor with a 12v source and works fine in both directions. I am getting power to the regulator plug but unlock seems to have less voltage???? Any suggestions on relays or what not. Fuses seem to be in good shape.
Thanks
C
chris bauer
las vegas
The actuator won't unlock even with the linkage removed. Randomly it unlocked 1 time today, so it may be a short in the wire. Going to run down wires.
jdeshong
Did you ever find the cause of your problem? Mine is doing the same thing, just outside of warranty. I looked up some diagrams and it shows the driver door unlock relay is seperate from other doors and is built in the BCM (body control module). I know this is an old post but hooefully you will get a notification and reply back. Thanks.
Sent from my SM-G930P using Tapatalk
Thanks
I have a 2015 Expediton Limited 4x4.
Why would you remove the window regulator to repair the lock mechanism? Did you mean the door lock actuator and not the regulator? Also - what is the "tinfoil fix"?
