“Thunder” 1998 Expedition Build Thread
MISTERgadget
MISTERgadget
Miami
I'm having mine cleaned up a bit, mostly to get rid of the Lincoln Logo.
BaggedExpy
Derby
@MISTERgadget. You did get the trim piece that goes behind console on the floor? Its where the floor steps up. There different if you have bench go to buckets. The console has cutouts for it and also gets rid of the hook where bench latched into. Youll have to cut the hook off or unbolt it.
dschallmo98expo
FL
Tampa. When I go to Miami next month I will drive it over and you could check it out. Then I can look at yours.
dschallmo98expo
FL
No emissions in Florida. However I still have all sensors and egr equipment to reinstall if needed and a tune that has the egr working. That is if I move to another state and it requires emissions
Clemson82
Pinellas County, FL
I wanna get rid of that logo also. How can i? I figured if i started cutting thread there'd be a embossed logo after it was removed
FYI - I just had a single panel replaced on the drivers seat of my Benz where the leather had cracked slightly. It was $100 at the local upholstery shop, matches perfectly. The car was there for one full day.
MISTERgadget
MISTERgadget
Miami
Happy hunting on Saturday for a truck with the rear captains chairs so I could get the floor anchors. I also picked up the panel that goes under the pedals and has some sound insulation from that same navigator.
dschallmo98expo
FL
Also. I want to make my front seats cooled. I have the fans and ducts that mount under the seat. How does it work?
MISTERgadget
MISTERgadget
Miami
How did you cut them out?
I have an ingersoll rand cordless body saw
No idea
Thats alot of work. But itll look stock when done
That's what I'm going for!! It shouldnt be too bad, figure we just need to cut the holes for where the latches will sit on that "shelf", let them nest in there, and a few rosette welds around the outside diameter will hold it in, imitating how ford sets them up with spot welds.
acolic
Hamilton Ontario Canada
Unfotunately I'm out of town on a business trip! Will have to be next time!
This thread is driving me crazy with all the possibilities for my 99 Expedition Eddie Bauer.
A couple of questions.
Was the motor you built a direct drop in replacement?
You must have a 2wd Expedition as I could not find a Belltech rear sway bar for a 4wd Expedition?
Why did you change the differential? What can the new differential do that the stock one cannot?
Can you explain a bit more about the Hydro-Boost install. Did you just need a Hydro-Boost and a spacer and it was a direct drop in install or was there more involved. From what scrap vehicles can you pull a compatible Hydro-Boast from?
Great thread and thanks for the answers in advance.
