Best lube, IMO for Power running boards is...............
jeff kushner
North of Annapolis
Motorcycle chain lube!! I realized this last year right after buying my truck and it's PERFECT for them! Chain lube's come as sprays that are very viscous when first applied and it easily flows into the pin shafts, joints etc. Then, after a few minutes the carrier fluid evaporates and leave the lube behind....it really is the perfect lube for these assemblies! BE SURE TO USE PRIOR TO WASHING YOUR TRUCK!
You def don't want to apply this AFTER getting all the parts wet so do it before you wash your truck!
I've been meaning to post this and kept forgetting!!
Here's an example but there are a hundred different brands...any of them will work....just stay away from "chain wax"...it's a similar but different material. It will work but wax does not lubricate like grease! Most are using WD40 which is a very non-resilient lube but it does work....the chain lube is worlds better though!
jeff
ExpeditionAndy
Fort Wayne, Indiana
jeff
@jeff kushner I have been meaning to look into this but haven't yet. Where are the pivot points or what points do you lubricate on the running boards?
gixer2000
Retrofit or Bust
Massachusetts
Open your doors so they deploy and look under. Do every moving part with the stuff Jeff recommended. I sprayed a friend of mines escalade with this same stuff last year after they started sticking. They've been 100% flawless since. But again it's very important you get every moving part and pivot point
ExpeditionAndy
Fort Wayne, Indiana
Is that something that you can easily see from the top side? I know where the pivots fore and aft but I can't fit under the truck to really watch in come down.
gixer2000
Retrofit or Bust
Massachusetts
Got a small mirror? Some of the points can't be seen from above. A mirror and a straw on the lube would probably do it for ya
USMCBuckWild
Camp LeJeune, NC
In!
I tried white lithium grease and it worked for 3-4 months. I am contemplating disassembling and adding the bronze bushings and grease fittings I saw in that running board thread.
Muddy Bean
Yeah me too! I’d like to read that thread
rjdelp7
2000 XLT
NY
A couple of bad Buffalo winters, these "power" running boards, will be toast. Hell, my original brackets rotted away. They collect the snow/salty mix.
llhoneymoons
us
I have an unlimited plan at the local car wash and go about once a week. I deploy the running boards just as I go through.
ExpeditionAndy
Fort Wayne, Indiana
I have the unlimited plan at Mike's Carwash here in Fort Wayne and I go through at least once or twice a week but I have not deployed the running boards before going in. I never considered that. What specifically does that do for the running boards?
llhoneymoons
us
I'm not 100% sure if it does anything to protect them, but they do look nice afterwards when they deploy. My other hope, besides them being clean, is that any dirt or salt (winter's coming) will be removed and prevent rust. My other two cars have both had rusting at the rear wheel wells. I just paid someone to have that removed so it does not spread. I would prefer not having to do that with the Expedition so I am being sure to keep it as clean as possible.
ExpeditionAndy
Fort Wayne, Indiana
Me as well. I had the truck Ziebarted when I bought it. They spray the jell in all of the panels and the rockers, I even got them to do the radiator support just in case. And they undercoated the entire bottom of the truck. Everything that doesn't move - they call it sound deadening but we know what it really is for to keep it from rusting away.
It’s not so much that they rust but after being iced closed and the salt getting in the internals you are correct they break. My family member who buys new GM units every few years always says they wish they could get a denali or LTZ with fixed boards because their running boards generally fail after about 1.5-2 years. In a heavy freeze where the things are coated you can just hear the motor struggling to deploy them i think that’s what kills them. If your not in an area with extreme winters they are pretty reliable.
ExpeditionAndy
Fort Wayne, Indiana
Here we can get really cold winters with temps in the minus teens but that is unusual. We typically get about one snow fall per week usually only a couple of inches and sometimes not at all. We get lake effect snow but we are far enough away that they are usually just flurries here.
When the weather is bad, I stop at the car wash on the way home and run it through to get most of the salt off and then when storm is over and I'm going out, I'll stop at the car wash to wash the rest of the salt off.
rjdelp7
2000 XLT
NY
JExpeditions07 says they freeze shut. Running it through a car wash, below freezing will guarantee that. I would pull fuse Dec-March.
llhoneymoons
us
Can you share the fuse location?
Is that fuse tied to any other component(s)?
