superchargers or turbos
mmrseed
Huntsville
need a lil more info...what kind of power are you looking for? Either way, if you want a power adder then you shouldn't be concerned about fuel consumption cuz that'll be gone with either. Also, while I am aware of several types and brands of superchargers for the f150, I don't know of any turbo kit for an expy or non diesel ford so a LOT of fabrication will be necessary and now you need to look at what you want to spend unless you can do all the work yourself
KWT2000
NINE MILE FALLS
turbonetics makes a kit for ford gas powered trucks however i would go with a self contained supercharger for the easier install and maintence... turbos work great on fast reving gas motors because they are easier to keep cool and on diesels where you can hit 1300 exhaust temps with causing harm, 600 degrees on gas motor is about max. besides the plumbing of the turbo would be a pain with the oil lines and coolant lines and intercooler.. unless your bulding a race truck i would go with supercharger... as for gas mileage forced induction will hel if driven rite but it can also kill the mileage if you keep your foot in it
tritonman5.4
tritonman5.4
brooklyn ny
being that my truck will still be a daily driver im gud around 450 to 500hp (but torque is where its at u know) to all four wheels,and as far as price go,not really worried about that
tritonman5.4
tritonman5.4
brooklyn ny
i really leanin towards the SC but the only bad thing is tunnin u know,not all i wonna be smokin all 4 lol turbo set up can be tuned to different specs but the head aches that comes after isnt worth the amount of money i will pay 4 installation
mmrseed
Huntsville
the most recent ford lightning made 360 supercharged horsepower. If you want 500, it isn't gonna happen with just a power adder unless you run about 16lbs of boost and then you'll only be able to step on the gas pedal one time. To avoid grenading your engine, if you want 500 hp, it'll probably cost you about $15-18k to build your engine and put the blower on it. Or just spend $29k and order a shelby gt500 crate motor :)
tritonman5.4
tritonman5.4
brooklyn ny
lol i jus luked up some different force induction systems and saw how much they cost,price really isnt a concern but damn every1 has a limit,i recently discovered that ford have made a thunder expo in 2000,it had the same power and drivetrain out of a lightlin and its number was impressive wit only 360hp and 440lbs tq,i mean dude this thing was knockin on the doors of sum decent to high end sport cars,and ford never put the damn thing into production that lightlin serious set up doesnt sound bad
KWT2000
NINE MILE FALLS
i agree that you wont see 500 horse with just a induction system. tritons are truck motors and make good torque. i understand it is easier to asjust a wastegate or blowoff valve to keep the turbo under control but they also fail very easy the main reason my powerstroke doesnt have either one. in that regard you can put the pulley on for your desired boost and walk away with less worry and cash.. i also think you will be surprised if you get 350horse and about 400 torque it will be a very quick expy
Stoned06
Milwaukee
Lightnings made 380 at the crank with 8# of boost, and about 330-340 at the wheels. With a 4 lb lower pulley and a good tune, it would be about 400 at the wheels, or roughly 500 HP at the crank, and nearly 500 lb ft of torque at the wheels. That setup works well, and is fairly safe with a good tune.
I say find a wrecked L and gut the drivetrain, the only issue will be the computer is setup for 2wd and not 4wd. You can just pull the topend blower setup off (and intercooler), and get a tune for your existing computer, but you need a lot of supporting parts to make it work right. I posted a link to the parts list a few weeks back in another thread. http://www.nhtoc.com/vbforum/how-se...89-how-add-svt-supercharger-5-4-n-engine.html
There is someone on the Lightning forums with a lifted 4x4 crew F150, and he did the swap. I think his SN on lightningrodder.com is Z7What. Try to find out what all is needed for the 4wd guys from him.
Your bottom end should hold up with no more than 14 lbs of boost, but I would stay safe at 12. The weak spot may be your tranny if you do not have the 4R100. If you have the 4R75, it will detonate within 5-10K miles with that much torque.
tritonman5.4
tritonman5.4
brooklyn ny
i agree im really gonna go with the lightlin set up
tritonman5.4
tritonman5.4
brooklyn ny
Lightnings made 380 at the crank with 8# of boost, and about 310-320 at the wheels. With a 6 lb lower pulley, it would be about 400 at the wheels, or roughly 500 HP at the crank, and nearly 500 lb ft of torque at the wheels. That setup works well, and is fairly safe with a good tune.
thanks dude really apreciate the help
utah
STS makes an awesome turbo kit the up side to a turbo kit is your not drawing power to make power your using the waste of the motor to produce power ans with the sc your having to push the pulley to get power both work well a guy i work with had a 05 f150 with a turbo kit on the 5.4L and it was really impressive when he was towing his 25 ft cobalt boat
KWT2000
NINE MILE FALLS
i gotta throw a caution about towing with a turbo charged gas motor as for the extra heat turbos produce and the non reliable charactoristics of a waste gate and blowoff valve not to mention gas engines are not designed to handle exhaust temps over 600-700 degrees... just be careful
gjhanson2
Orange County, CA
Check out Procharger, they make good centrifugal chargers for the Expy's and you can get them with or without intercoolers. As for turbos: those are only for diesels and ricers.
tritonman5.4
tritonman5.4
brooklyn ny
good deal,hey i posted to reply about my trip to alaska
Steps
Denver, CO
That is a boneheaded statement. Vinny Barber runs 8.4 seconds @ 164 MPH in the 1/4 on a single turbo built S197 Mustang. Is that RICE?!?!
http://www.s197forum.com/forum/showthread.php?p=83971#post83971
Check out that ET list and the 1/4 times they are running with "ricer" turbos. There are 6 Mustangs on that list running 9 seconds or faster with Turbo power adders.
Turbo has nothing to do with Rice. Rice = people that do dumb things to cars like 10ft. wings, 50 stickers, and yell out "I got NAWWZZZZ BRO!" everywhere they go.
Steps
Denver, CO
Honestly, I was not making this personal...I attacked a statement that Turbo's are for rice, thus the comment "Boneheaded statement".
I have no reason to get personal and would not do so.
With that said...I wanted to make sure people on the board undertood what Turbo's can really do.
seeker
Acworth Ga
Go supercharged
Turbos can add more heat to your engine, shorten oil life, coke up oil lines, and generally cause a lot more maintenance issues. Superchargers are less head aches.
