LiverpoolFC
So here's the build sheet of my '07 SSV.
A great deal of things I understand but some I am unclear about and some don't appear to be correct. Will highlight each of the questionable items and hoping that someone will chime in with info/comments.
- Medium Light Stone Interior
- Beck (D) - what is it?
- With Fr.Sus/Trans/Fuel Skidplates
- With Manual Liftgate
- With Under Floor Stowage - Where is it?
- 119"/3023MM Wheelbase
- XLT
- Less Special Purpose Vehicle
- Michigan Plant Built
- U.S. Sales
- Less Convenience Group
- Less Military Vehicles
- Special Services Vehicle
- Less Exterior Appearance Pack
- Less Sales Feature - Level 1
- Less Memory Package
- Feature Content Group 1
- 2007 Job #2 Program Control
- Less Electronic Stability Control
- With Safety Pack
- With English Language Label
- Owner Hand Book Pack
- With Fixed Rear Vent Quarter Window
- With Privacy Glass
- Less Overhead Console
- Less Floor Mounted Console
- Less Rear Floor Console
- Fixed Foot Pedals
- Interior Trim Accent Pack A
- Vinyl Floor Covering
- Less Front Floor Mats
- Less Rear Floor Mats
- Sunvisor - Dual Drv Non-Illuminated
- Sunvisor - Dual-Pass Non-Illuminate
- With Stowage Bin - 3rd Row
- Rear Coat Hook
- Less Cargo Stowage Rack/Rail
- Less Running Boards
- With Accent Colour Grille
- Roof Rack Without Crossbars - no roof rack. Maybe was removed.
- Less Exterior Wheel Lip Moulding
- Lower B/S Moulding-Molded In Colour
- Less Side Auxiliary Step
- With Dipping Rear View Mirror
- With Driver Electric/Heated Mirror
- With Pass Convex Elec/Heated Mirror
- With Black Exterior Mirror
- Less Signal Mirror System
- Less Temp Control Driver Seat
- Less Temp Control Passengers Seat
- With Vinyl 2nd Row Seat Material
- Second Row 40-20-40 Seats
- Less 3rd Row Rear Seat
- With Driver 6 Way Pwr.Seat Adjuster
- Less Adjustable Passenger Seat - Seat has wiring/motors. Wires from seat to floor are cut. Can reattach but need a side panel with rocker switches.
- Less Programmable Driver Seat
- With Heavy Duty Trailer Towing - See tranny cooler option
- With Front Towing Hook - don't recall seeing one... but there's a bull bar
- Exterior Door Handle - Black
- 4 Door Wagon
- With Door Entry Remote Control Unit - below
- Less Keyless Entry System - Are these two the same thing? I used a cheapo remote to program and it works.
- Less Sun Roof
- Front Bumper - Body Contrast Colour
- Rear Bumper Body Coloured Plastic
- With Front Licence Plate Bracket
- Air Curtain Restraint LH
- Air Curtain Restraint RH
- With Driver Air Bag
- With Passenger Air Bag
- With E-Coated Steel Spare Wheel
- With 4 Wheel Tyre Pressure Sensors - Do I get a warning on the dash if tires are low?
- Less Front Shock Absorbers
- Less Rear Shock Absorbers
- 7.5 X 17 Steel Wheel
- P265/70R 17 A/T OWL
- With Super Engine Cooling System - Any different from regular engine cooling system?
- Less Immersion Heater - What is this?
- With California/Green State Req - Of course... Can't wait to move away from this money pit!
- With Standard Suspension
- 3.73
- Rear Axle Limited Slip Differential
- 5.4L 3V V8
- Less Exhaust Pipe Extension
- With 4 Wheel Disc-Brake
- Normal Fuel Fill
- Less Remote Starter - FIA
- Heavy Duty Aux Trans Oil Cooler - Does this mean I have the 9k lbs towing package?
- 4X4 2 Speed Transfer Case With Tod
- Non Locking Fuel Cap With BP Label - Interesting detail, yes BP is there.
- For Unleaded Fuel
- With Man Rake/Col Shift Strg Column
- Colour Keyed Steering Wheel
- Less Steering Wheel Audio Controls - I suspect the wiring might be there, will look
- With MPH/KMH Speedometer
- Less Message Centre
- Less Reverse Proximity Sensor
- Heavy Duty Battery - guess back in 07 it was. Now it has a new 2017 battery.
- Heavy Duty Alternator
- With Premium AM/FM Sterio/CD
- Less Radio Reception Equipment
- With NAAO Radio Frequency
- Less Headphones/Sockets - Rear
- With Premium Sound System - It sounds good but 4 speakers is hardly "premium"
- Less Television Package
- Less Garage Door Opener
- Less Optional Equipment Pack
- Less 4X4 Version Pack - Is this a 4x4 related package?
- Less Comfort Pack
- With Complx Refect Headlamp Design
- Less Daytime Running Lamps
- Less Front Fog Lamps
- Less Interior Courtesy Lamp
- With Automatic Headlamp On/Off
- Ebony (Solid C/C)
- Generic Country Group 1
- Ford Series
- Less B&A Control Codes Issue 030388 - ? whats this, and the one below?
- Less B & A Control Codes (9270)
- With Overspeed Warning Disabled
- 6 Speed Auto Trans (6R75)
- Expedition (2003-)
- (-)"N"
- (-) GVMT Service Administration
- (-)"CDN"
- (-)"RA" ============What are these things? I guess (-) means not there
- (-)"GU"
- (-)"BRN"
- (-)"CHN"
- (-)"AW"
- Fleet
