15-17 Heated Steering Wheel?
East-TN
Air Force
TN
On another post it was mentioned the Expy didn't get a heating steering wheel as an option until the new 2018 model. Is this true?
Does any 15-17 Owner have a working heated steering wheel option on their vehicle? Trying to determine if it's possible to add this to my 17 Expy. Thanks.
I ordered and purchased a new 2015 Expedition Limited 4x4 - a heated steering wheel was not available on any trim level through 2017 (standard or extra-cost option).
Ford only used the heated steering wheel on their uplevel vehcicles such as the Focus.............
Another thing I don't like about my Expedition.
J Ski
3.5plati
VA
He just said they were not available until 18 on expeditions
J Ski
3.5plati
VA
And asked if any 15-17 owner has the working heated steering wheel option.
There was no heated steering wheel option.
Yeah I know, OP obviously didn’t trust the other guy who told him they weren’t available until 18. Just a redundant thread
Trainmaster
Old School Member
Rockaway Beach, NY
Some folks can do work themselves and add options that were not available originally. Perhaps the OP was seeking information to get a handle on what can be done, as he said. The first step would be checking availability, which sounds like what he's trying to do.
The limiting factor here would be the "clockspring" that carries power from the steering column to the wheel. All the 3rd Gens share the same one, I believe, which has a bunch of terminals to provide transfer of radio and heater controls, horn and cruise control circuits to the steering wheel. While many cars don't use all the conductors, they are all low amperage, so they probably wouldn't carry the load for the heater on a 2018 heated wheel. The OP can check this all out of course by comparing the wiring diagrams of a 2018 vs 2017 and compare the wire gauge for the heater harness vs the available leads on an earlier clockspring. He could then compare part numbers for heater vs non-heated clocksprings, Gen 3 vs Gen 4 cars.
Now if anyone had a heater on his 3rd Gen Expedition, the research would have been done for him. That information would be more helpful to the lad than a string on insulting remarks based on information gleaned from a Google search.
John Christopher
CT
That's funny!!!
East-TN
East-TN
Air Force
TN
Uhh...if it’s ok with you I was double-checking the information posted. Plus, if the info is correct (no HSW until 18) I wanted to see if anyone has modded their Expy yet and see what they did to get the HSW function.
Isn’t that part of the value of these forums...gather info/learn?
AllBoostNoEco
GA
The real issue with adding a HSW to the 15-17 Expedition is that it shares the basic architecture with the 11-14 F-150, which also was never available with the HSW. Otherwise it would be a simple swap with possibly some wiring, because the existing architecture would readily support it.
As the APIM is shared with vehicles that did come with a heated steering wheel, it is possible that the outputs are present and active for the ability to add one once you activate it in FORScan. However, I haven’t been able to find out if any of the vehicles that came with one are physically capable of being swapped into the Expedition, nor if the wiring would be compatible in the steering column if it does physically fit.
There are no examples of anyone swapping a HSW into an 11-14 F-150 on any of the forums that I’m a member of. Same with searching through the web.
star-art
Pacific Northwest
Heated steering wheel is available on 2015+ F150 which is different from 2015 Expedition (it's more advanced with more and different options that we can't get like 360 camera and adaptive cruise control). I've seen only one thread that I know of where someone added it to an F150. You'd have to swap the clockspring, but that could be the easy part. Problems for us include the fact the steering wheels don't match (the buttons are different). There is also a module to control the steering wheel heating element (it has temp sensors and a feedback loop, it doesn't just turn "on" and stay that way). In the F150 thread, programming was needed to get the module working and for the heated steering wheel button to show up in the 8-inch display. I for one would like to attempt this swap, but further study is needed to see how to get around the steering buttons being different.
edizzle
Cashiers
HSW is the nicest option that you don’t need!!!! No one really needs it, but once you’ve had it.........
rcompart
IL
Agreed. Some of these new creature comforts are beginning to be like electricity and running water. People used to do without and had no trouble doing so but how the heck they did is beyond me. LOL
John Christopher
CT
Keep a pair of leather gloves in the truck and put them on when you get in. You will look stylish and the hands will be warm. Lol That what I do and it works great.
Disagree I think people are perfectly fine without “creature comforts”. My F-350 is newer and has heated seats and sync and my expy has none of that, I like the expy just as much.
rcompart
IL
What about your power steering and A/C... You think you’d like your Expy sans those “creature comforts”? LOL
star-art
Pacific Northwest
You guys are too funny. :) I found the thread on the F150 HSW retrofit. There was one fellow who successfully did it and he wrote up a detailed guide but has since taken it down, not sure why. The hardware portion of the install seems fairly straightforward. The tricky part lies in the software "tweaks" needed to get it all working. There is a new HSW Module that needs to be installed. An icon in the 8-inch dash display needs to be activated, along with communication between this display and the new module. Finally, for vehicles with remote start, there is a setting (at least on F150 trucks) in the instrument cluster to activate the HSW during remote starting.
Here's the entire thread:
https://www.f150forum.com/f118/add-heated-steering-wheel-314154/
star-art
Pacific Northwest
OK, this is interesting! According to Motor Trend, the 2015 F250 Platinum has a wood/leather heated steering wheel. This wheel happens to be the same design used in the 2007-14 Expedition. SO, if it can be confirmed that this wheel is indeed heated (we'd need to confirm by looking at a Ford F250 sales brochure) then it might be possible to add a heated steering wheel to any 2007-14 Expedition without having to deal with customizing the buttons!
AllBoostNoEco
GA
Ford’s 2014 Super Duty brochure says the Platinum came with one. If the wheels are the same, then it just might be possible. It sure wouldn’t be the easiest mod ever, but if you want one, I’d encourage you to go for it.
Wish the 15-17 Expedition had a vehicle it shared the steering wheel with that came with a heated one.
This is correct, the steering wheel in my 07 Expedition is the exact same as in my 2013 F-350, so maybe possible on our 2007-2014 units. My SD wheel is leather wrapped with the controls but I don’t have heated.
