Ecoboost Oil Change
DF5.4
Hilton, NY
Whoever designed the Ecoboost is these probably said "Oil changes are not my problem". I get the front up on ramps and use an small impact driver to get the cover off. Not a big deal. Drain the oil. Not a big deal. Replace the filter without making a mess. There's the problem.
Yeah I'm not a fan of the plastic covers underneath or the filter situation on the ecoboost, just complicates things.
Boose
2017 Platinum EL
NJ
Even my 05 5.4 was sloppy with the filter change. Every oil change included a can of break cleaner to rinse the residual oil off of the block/front axle. A remote verticle oil filter with clearance underneath is apparently too much to ask for!
Did your 05 not have the channel? mine has a plastic channel the oil from the filter drains to you just put the pan under it. I never get more than a few drops out of place and the changes are easy as can be.
Boose
2017 Platinum EL
NJ
No, it did. It seemed like the drip channel didn't extend back far enough. I always had a small stream of oil drip down the back end of the front differential. I always changed the oil with the front end jacked up, not on a vehicle lift though. Maybe that was the problem, giving it a nose up attitude.
lbv150
Northeast
I'm not happy with the '16. I installed a drain valve on the pan to make it a little easier. The filter is the hardest to get to....have to reach up and do it blind.
jeff kushner
North of Annapolis
I hate to admit this....especially as a building of high performance engines but I'm also pragmatic and it's just easier for me to pickup my Mobile 1 5-30 Syn, Pur S500 and give them to my local Grease & go guys who charge me 35 bucks....no muss, no mess and they are very good about wiping everything down.....
Ford just made it "not worth my time".....so I don't waste it....
jeff
John Christopher
CT
I don't change my oil anymore. I have it done for $25 to 28 so the savings by doing it myself is minimal. I'm curious why you guys continue to change yours. Is it because you like to know it's done right and get satisfaction working on your truck? I still do some maintenance and repairs on my vehicles, just not oil changes. Thanks
Boose
2017 Platinum EL
NJ
So... I did the first oil change on the 17 on Saturday... What a pain in the ass... Glad the dealer gave me free oil changes for a few years. The only reason I did this change is I didn't want to keep the break in oil in there for 5k. With the front end jacked up, the filter residual ran down the back of the tin plate under the motor. the plastic channel is useless unless the truck is level. Both the felt-like panel below the transmission and the tin plate below the motor had to come off to be cleaned afterwards... This truck is apparently designed to have the oil changed completely level.
I do it so I know it's done right with the oil and filter I want to use. Takes me all of 10 minutes. I'm not a big guy so I scoot right under it with no jack drain it take the filter off put the new one in and refill it. Mine takes 7 quarts on the nose with filling the filter. I have it down to the point I can do it in my sleep and it's painless. On my 07 there is nothing that impedes though, no plastic panels or hard to reach filter, it's all readily accessable.
Boostedbus
I changed my 17’s oil at around 3000 mi for the same reason about break-in oil. I noticed the factory filter was longer than the MOTORCRAFT FL 500 that my manual calls for and it was only marked FO-MO-CO and no numbers. I guess that was just a break-in filter. I’d like to find out what number it was because there is plenty of room for a bigger filter like that one.
Did yours have a FO-MO-CO filter?
Boose
2017 Platinum EL
NJ
Yes, that's exactly what I had... THere's plenty of room for a longer filter. It honestly would make changing it easier as it sits so far back.
Boostedbus
I googled it and the long filters are MOTORCRAFT FL 2055 which are discontinued now. Might be able to find some old stock somewhere but the FL 500S is the new replacement number
Boose
2017 Platinum EL
NJ
just wondering, why not use the FL1A on the 351?
Paddler
Utah
My local Jiffy Lube wants $45 for regular oil, more for synthetic. I can do it for less than half the price.
Boostedbus
It’s got a factory oil cooler that the filter spins on and it looks like the old FL1A would have crossmember clearance issues.Back in the day all my work trucks and cars all took the FL1A and it was simple to just stock one size fits all... not anymore I have 2 diesel 7.3 trucks and both are different because one is non turbo and other a powerstroke, two 5.4 vans and my personal 351W F150 are all the same FL820S, but wife’s Escape takes FL910 and of course now the new Expy is the FL500s ,my 99 Jeep TJ takes little MOPAR filter and now my 390FE 69 Cougar is the only FL1A recipient left. I’m like Jiffy Lube in my spare time!
