Looking for a solution, had my truck regeared to 4.56s and I replaced the front axles because they were shot, with the new axles in I’m getting grinding on turns and over bumps, which I’m told is due to the hubs staying engaged (stuck in 4WD) and I’m apparently hearing the typical binding just at higher speeds. I need a fix for that so they won’t be engaged at all times because they’ll break my axles very soon with the angle they sit at. I’ve replaced the IWE solenoid before and the transfer case motor but as far I know the hubs are original, wheel bearings are original, and the lines are original. Bought truck with 122k now has 155k 2006..
thanks
thanks
