Yup... and it you want to raise the truck a little more and raise the suspension parts you can get taller tires.
Love the wheels and bumper!
Not on a 2014. Pretty sure they only offer strut spacers right now, no actual lift kits that I’m aware ofYup... and it you want to raise the truck a little more and raise the suspension parts you can get taller tires.
Huh?Not on a 2014. Pretty sure they only offer strut spacers right now, no actual lift kits that I’m aware of
He said if you raise the suspension components you can get taller tires. Only way to raise the suspension components is with an actual lift. Thts how I took it. IdkHuh?
I think what @VancouverBob was saying is the only way to gain more lift is with the addition of taller tires.
Sent from my SM-G935P using Tapatalk
What year?Just ordered my readylift spacers!
I'm hoping to put them in in a couple of weeks with the help of a friend. Eventually I'll buy bigger tires and then I can really climb into my Expy.
I LOVE this f'n truck!
2014 Limited with the 20" rims and power running boards.What year?
I'm not looking to make it stand out, I just want to get it closer to the first generation height.
Any recommendations for tire sizes?
I’ve got 35/11.50/20 tht fit. 33/12.50/20 fit too on OEM wheels2014 Limited with the 20" rims and power running boards.
Should still fit. Just more side wall. As for tools, check out Readylift site, they have downloaded instruction manual for spacers that lists tools needed. Definitely wanna have an air powered impact wrench. Will save you 3-4 hoursI'm wrong, I have 18" rims.
Thanks for the help!F150 uses standard shocks in the rear, the Expedition uses a strut assembly. So you’re stuck with Expedition-specific parts.
https://www.rockauto.com/en/catalog/ford,2014,expedition,5.4l+v8,3305849,suspension,strut,7584
They show quite a few different options, including Monroe and KYB. You might also consider upgrading to the factory Nivomat load-leveling shocks.
Ford lists a different coil spring and upper mount for those versus the standard shocks, so whether they are a direct replacement for standard shocks is something I’m not 100% clear on. Just something to be aware of.
Any way to tell if I already have the load leveling rears without taking the wheel off?
I think I have the towing option. I can see the factory buttons up front just above the center console and there are wires hanging by the hitch.
God luck! It’s a fun time and really changes the trucks appearanceMy 3/2 readylift spacers will be here this week!
I just ordered some new jack stands, misc tools, and a dewalt impact wrench. I'm pretty excited right now.
