I’ve always run Motorcraft 5W-20 and changed it at 3,500 mile intervals using an FL-820S filter.... my truck has alwasy ran good and quiet.
I was watching a makuloco video on oil pressure testing the 5.4L and he highly recommends owners of 3 valve 4.6L and 5.4L motors to use 5W-30 oil. Many disagree on this but I decided to try it, bottom line is I notice no difference except the engine is quieter than with the 20 weight when at running temp. 163,000 miles. I guess it would make sense that as he says the 5-30 keeps pressures higher at temp than the thinner oil. As we know low pressure wreaks havoc on modern variable cam timing systems. Never tested mine but decided to try something different. As I expected not much difference as it’s only one grade heavier.
