Roof rack cross bar removal
GoBison
FARGO
Has anyone removed them? What does it take? I'm not a fan of how they stick up above the chrome side rails. Are they easy enough to remove and install as needed?
proeasy
Michgan
Picked my truck up this morning. This was the first mod. Just need a torx wrench.
rcompart
IL
It looks nice and clean sans the roof bars. Also, it was also a pleasure meeting you today.
I was on the fence pulling them off but if I’ll ever need them, it’ll be when they’re not on there and I wouldn’t have the luxury of going home to install them. I did move the front one to the middle set of holes and swapped out the torx head fasteners for the eyelets that come on the Explorer so I can move or remove them without tools should need arise.
Part number is FB53-78551A72-AA3YZ9 for anyone interested in doing the same.
proeasy
Michgan
Hey,,Did not know that was you. Great meeting you today. Went across the street to Home Depot and got a “TORX”. Kit for $10 before my 250 mile ride home in my new Expy. Looking foreward to some fun in the snow with proper winter wheels.
Paul
aggiegrad05
North Texas
I removed mine as well. If I have enough stuff that I can’t fit it in the back of the Max...I have too much stuff! Plus, the manual limits you to 125 pounds up on the roof, so it’s not as though I’d be hauling anything major up there anyway.
Meeker
Calgary, AB, Canada
I'm keeping mine on - and it's good that they stick up above the side rails! You need your canoe as high as possible so you can lift the tailgate...
twernst
Manahawkin, NJ
Can you provide Pics of part? This was one of the first things after I got back from my trip to FL to pick ours up and bring her home to the Jersey Shore.
Fordalways
North Central Texas
I also removed mine as I’ve never had the need to carry anything up there. Mine had plastic caps covering the actual torx screws that had to be pried off 1st. I placed a towel under the end of each bar to protect the paint as I was doing the removal by myself. Being a bit ocd, I got a dozen plastic plugs from the local auto parts store and pressed them into the empty screw holes.
lbv150
Northeast
I removed them the first day home from the dealership on the '04 & '16.
EdWeg
Army
Birmingham, AL
Granddaddy 2007 XLT here. At least you've not experienced what I have. Someone needed a fastener, and so I'm now missing one. The '07 fastener has a longer thread base; but, is basically the same, and had to take some time to be removed. Try and find just one!!! I just went ahead and removed the cross bars too for a cleaner look. Someday I may replace if ever really needed for moving something bulky.
rcompart
IL
If you only need one, PM me with your address and I’ll toss one in the snail mail for you.
twernst
Manahawkin, NJ
I called my dealer after coming back from FL as I was missing 1 or 2 of the "fake" ones for the extra spots. They dropped in the mail right away
VinnyTL
New Jersey
What size Torx Screwdriver do you need to remove the cross bars? And can I fill in hole with a torx screw to prevent rust and build up in the exposed hole. Any info will help.
Highlightreel
MN
T30 torx I believe. There's another forum post that discusses this as well. 5 minute job. I just replaced the metal screws into the same holes. The light grey ones in the pic were plastic fillers in the other set of optional holes. The original ones that held the bars on do stick out a bit, obviously, but they have stayed snug and only barely hurt my mpg!
