How does one remove the dash cubby? And for you folks with the fancy models what is this button??
Black
Kentucky
Looking to add the brake controller so curious if one just pulls the cubby straight out or if the panel needs to be removed and something unclipped from the back?
Also for you folks with the fancy models what button do you all have to the left of the hill control and traction control button??
Bigbadbull
Hoover Al
Left blank button is the power tail gate
the Hill decent button is blank on 2wd
The Cubbie is the Trailer brake controller (same spot on 2008-2014 F150's)
Black
Black
Kentucky
Clear on the cubby.
To remove it do I just pop it out or is it attached on the back that the silver panel needs to come out as well?
AllBoostNoEco
GA
Clear on the cubby.
I’ve never taken the dash apart in the Expedition, but looking at the way it sits with that lip, as well as looking at pics of the OEM TBC, it pops out. It’s tough, I tried removing the one from my wife’s truck and gave up because it felt like something was going to break.
Black
Black
Kentucky
This is exactly where I am at. Wanting to make sure there are no tabs that have to be released from the rear.
I am replacing the cubby so don’t really care if it breaks. Just don’t want to break any portions of the silver panel as I am going to presume they are not cheap.
chuck s
I used the wonderful proportional Tekonsha Prodigy brake controller on my Explorer and '07 Expedition and was apprehensive the built-in OEM controller in my '17 Expedition was as good. Shouldn't have worried as it's just as good and does things like detect burned out trailer lights.
Expedition and F150 bin/brake controller or mounts different? The top video makes the bin just snap out; the bottom one has the bin bolted in. First installation looks easiest but the bottom ain't bad and the guy is probably doing this one-handed and holding the video camera in the other hand.
Gonna have to tell the truck's computer the brake controller is there and my quick scan of the Forscan notes doesn't show the brake controller settings. Not unexpected as all the Forscan notes I've seen are about modifying settings, not adding hardware; probably no one wants to defeat the built in brake controller.
-- Chuck
AllBoostNoEco
GA
-- Chuck
Yes, all the F-150 cubbies and TBC bolt in from the back, Expedition snaps in from the front.
Black
Black
Kentucky
Have not got around to it.
Not needed to tow anything so I have not worried about it.
I am pretty sure it just pops out. It is in there pretty good though and did not want to break it until I buy the controller.
Garyyuan
TX
I tried a little bit. I found if you put your fingers inside and push up, it will tilt upward. But I could not get further. However, this mean clearly it not the same as F150, which is screwed.
Garyyuan
TX
I got it today. See the pictures I attached.
If you put your fingers in and push up, it will tilt up and the upper side is popped out. Then wiggle up and down the front and you can get it out. You can see the TBC connector is connected to its back end. I ordered the OEM TBC today from ebay and hopefully can just plug it in as this box.
