Expedition EL vs Navigator L
LJ4174
Berks County, PA
Can I ask Navigator questions on this forum? :) After looking for an Expedition EL, Considering a 2012 Navigator L. Essentially the same truck correct? I know it doesn't have the low range 4X4, however I have an Excursion for that. :) Anything I should look for, consider or stay away from on the Navigator?
dlcorbett
Air Force
tx
If in good condition and you like it, get it. I was looking at an expy el a few yrs back and they are great. While taking one on a test(close to buying it) i stumbled upon a navi l. Same truck but better implemented, better headlamps, better seats, better ride, quieter, better interior and more soundly built. Only thing i didnt like over the expy the navi gives up some interior storage and cupholders oddly enough(expy has cupholders in doors and more storage up front). Both great, if you want a softer cushier more road ready car the navis fit that for me, though the expy is a far better looking car(if you get air springs, the expys ride will be almost as good)
L
LJ4174
Berks County, PA
What about flat towing? There is a very likely possibility we will flat tow this behind an RV. There is a thread that talks about a newer (2015+) expy, but how about the older ones? Just as good/easy? Any difference between the Navi and the Expy on this?
Muddy Bean
Can the earlier models be flat towed at all? We flat tow our 2015 but not sure about the earlier ones...
Adieu
SoCal
Gator has nicer electronics, smoother ride (somehow, despite seemingly using same suspension parts), much nicer audio... no 4L, and -4 cupholders
Oh and much better sound insulation
PS power boards and power liftgate are hella OBNOXIOUS though. I haaaaate that shit
L
LJ4174
Berks County, PA
HAHAHAHA!!! I think the power boards are cool, but I understand they break, etc. and not necessary. My wife really likes them. One of the reasons we are looking at the Navigator or the Expedition is my wife has neck and back issues and lifting the heavy lift gate and throwing groceries up in the Excursion has started to become an issue. She LOVES the power lift gate!!! :)
dlcorbett
Air Force
tx
Power boards and liftgate are also available on the expys.
L
LJ4174
Berks County, PA
I "think" almost every Expy we looked at had the power liftgate, even the ones I look at online. Almost seems standard at some point...
coolzzy
Idaho
+1 for the power liftgate. My wife loves that she never has to touch the backside of the car as it's usually dirty. Now if only Ford had thought to put a lip on the inside floor so that things don't roll out when you open the liftgate. A gallon of milk pulled that escape trick last week and we've now learned to pop the glass before unloading groceries and make sure nothing is gonna sneak out.
I had the power boards on my F150 and loved them but always in the back of my mind worried about them failing. They are not serviceable and must be replaced as a complete unit at an astronomical price from Ford. I wish amp made a power step for the expedition then you could just add them and buy parts to service them.
Flexpedition
midwest
FYI, AMP Research is and has been the OEM mfg of the Explorer and Navigator power boards, and replacement parts are available thru your Ford dealer as well as elsewhere.
L
LJ4174
Berks County, PA
I "thought" I seen somewhere where they said you could replace the motors on the power boards?
Flexpedition
midwest
Ford part numbers 9L7Z-16A507-A (drivers side) & 9L7Z-16A506-A (passenger side).
Dorman, for example, makes part #747-900 for the drivers side, on Amazon for about $150.
Standard Motor Products part #Z10600.
coolzzy
Idaho
Need to let all those F150 owners out there know about this. My understanding was Ford used a version of the amp steps but modified just slightly enough to be unique to ford. Maybe it's different for the expedition power boards, which would make sense since amp doesn't make a power board for the expy but does for the F150 despite them having similiar or identical mounting points.
