New member-2017 XLT trailer wiring question
David Edwards
Mount Olive NC
Just bought my wife a 2017 Expedition EL, the XLT version so it didn't come with the integrated brake control in the dash. It also doesn't have a connector for the 7 blade RV plug, but does have the 4-Pin flat connector and the hitch receiver. Two questions, shouldn't adding the 7 pin connector be fairly easy because the wire is already there, just taped up with a plastic cap on the end of it?, also is it true that if I install the in-dash OEM brake controller, I will have to take it to a ford dealership to get them to hook it to their computer?
Moderator
If you don’t have the 7 Pin, you don’t have the Heavy Duty Towing package. Your Max Towing if you have the 4x4 is 6700lbs.
https://www.ford.com/resources/ford/general/pdf/towingguides/17RV&TT_Ford_Expedition_Sep7.pdf
If you don’t have the HD tow you can add the 7 pin connector and a controller and install the ford HD trans cooler (easy as pie) and you officially have max tow (9,000 pounds).
D
David Edwards
Mount Olive NC
Sounds like I may be able to use this truck to pull my 25' camper(5500 pounds) if I can do the trans cooler. Also, the axle number on the VIN sticker is 15, what axle do I have? and is this axle okay for towing a camper the size and weight listed above? Thanks again
Moderator
If you have a EL 4x4, they only came with a 3.73, and that is the best one for towing.
Also, no trans cooler needed if you are under 6700lbs for a 4x4 EL with out the Heavy Tow Package.
Also, Legally you can only tow up to what your vehicle is rated for from the factory. PERIOD. Regardless of mods.
Yes, if you make the other Mods, you can probably physically safely tow up to 9300 with a 4x4 EL. Also, is the hitch a factory hitch or aftermarket? If aftermarket, is it Class 3 or Class 4, that also matters.
This is true, esp for insurance purposes
D
David Edwards
Mount Olive NC
Thanks for the replies, yes it is an EL but no it is not 4 wheel drive. With the 3.31 axle how much does that decrease my towing capacity? I'm fairly sure that the receiver I see on the back of mine is not a class 5 receiver, probably a class 4 or maybe even a class 3. Is there any ID that would tell me which class it is? Thanks
D
David Edwards
Mount Olive NC
From what I'm seeing on this thread, I may need to just stick with using my 2012 F-150 to pull the camper, the last thing I want to do is hurt the transmission in our 17 expedition.
Moderator
The link I posted above is the EXACT Towing guide for the 17 Expedition. It has ALL the info you are asking for. No need to look at the 20+ Page file that Chuck posted.
Just in case you don’t want to click on the link, the 4x2 EL with the 3.31 and with out the Heavy Tow package has a Towing Capacity of 6600. There are other details like Tongue weight and so forth in the pdf also.
As far as your receiver, you will need to look. Most have the weights stamped into them somewhere. You are going to have to look around it.
Also, for Clarity, the Receiver that comes with the Heavy Duty Towing package is a Class IV, not a Class V.
Hope that helps.
