Engine Power Loss (Momentarily) when making right turn
Chris Wallace
Burke, VA
Hi - New to Forum.
I have 99 Expedition XLT 4x4 w/ 5.4L. Have been experiencing this issue for several years without figuring it out. I don't drive it much - maybe 3000 miles per year. It is used primarily for trailering.
This started when I took a road trip out west w/ trailer. When making sharp and even gradual right turns, I have a loss of engine power, as if it is not getting fuel. This happens most times, so as an example, if I make a right turn, give it gas it goes, but then I lose engine power for a moment (1/2 - 1 sec). Then it recovers and goes as normal. Every time I think I fix it, it still persists. Here is what I have done over the course of the last few years (this is probably not a complete list):
1. Spark plug replacement and Coil pack replacement
2. Replaced fuel pickup/pump
3. Replaced fuel filter
4. Replaced Fuel pressure regulator on engine fuel rail
I have checked and rechecked all fuses, wiring connections. I have also checked in wheel wells to see if anything is happening that is causing a restriction or shorted wires = all good. Fuel pressure is good. No codes thrown. No engine light. Electrical power is not affected.
I do have an right side exhaust manifold leak - the notorious warped manifold syndrome that most F150/Expeditions experience (this is second manifold that was replaced by dealer 8/9 years ago. Not sure if I am getting air sucked back into the exhaust that is causing this??
I also had a spark plug ejection, that was tapped out and had an insert sleeve installed 4 1/2 years ago.
1955moose
Your exaust leak could definitely cause your stumble. Years back when cars ran with a richer mixture, an exaust leak was no biggie. But these days our Suvs look like a human flatlining on a scope. Amazing they run as strong as they do. Are you throwing any lean code?
Flexpedition
midwest
While parked in the driveway idling, does a sharp right turn substantially bog the engine down moreso than an equal left turn?
1955moose
Chris I think flex is thinking your transfer case may be engaging. Or a binding of the CV shaft. Do your hear any clicking when you turn and accelerate?
C
Chris Wallace
Burke, VA
I will check turning wheels while idle, but I do not believe it bogs down while stationary and turning in either direction. Condition is only when driving.
No clicking noises from front drive axles.
The loss of power is acting like loss of fuel for an instant and only when at speed. Slow turns has no affect.
Come to think of it, I always back into my parking space at the office and always with wheels turned hard right. Occasionally I feel a jerking like my suspension is making adjustments (it has air ride system.)
Club Expo
Memphis
Mine will shut off for a half second just like this. after owning it for 3 years I have noticed it only does it when I have a quarter tank or less like as if the fuel is slashing or something like that, hard to explain but I haven't figured mine out either! If I come to a hard stop then gas it it will do that every time.
C
Chris Wallace
Burke, VA
This happens no matter how much gas in in tank.
I checked turning wheels while idle and in gear (with brake applied). No change in engine performance.
Loss of power happened twice this morning. Both times when accelerating into or after the right turn. Sometimes it does it in the turn, other it happens just after the turn is complete.
I'm going to replace exhaust manifold - but dreading the nasty stud removal - i know two rear studs are non-existing - the rest look dicey!!
1955moose
If funds allow, maybe pay someone that's good with exaust, and in particular broken bolts. A broken stud is no picnic, especially when theirs 0 room to work. Be sure to have an angle drill, and all the tools/removers you may need. That and spray the hell out of every nut/stud hours before you tackle job.
