Spark plug questions/misfire
1955moose
I got a dumb question for any of the Ford corporate type mechanic/engineers out on the forum. Why would Ford put in a crazy 2 piece as they call it spark plug anyway? What are/were any benefits? Doesn't Ford still do research on how a new design holds up? And furthur, did anyone try to remove said spark plugs during say 50k or more driving time testing? If they had, and not sent that motor/sparkplugs to production, wouldn't they have caught the boner they did in the early stage? I guess I just think outside the box, and logically, maybe that among other things is my problem. I always think like an engineer, sans the pipe in my mouth!
gixer2000
Retrofit or Bust
Massachusetts
Unfortunately all manufacturers do this crap! They claim they do test these new designs but I'm willing to bet its just not long enough plus I really don't think they care once its off the lot. I feel like their outlook is more "get more of my cars on the road" vs lets make the most trouble free reliable car possible.
Trainmaster
Old School Member
Rockaway Beach, NY
If you recall, the earlier 5.4 L engine was plagued with a different spark plug problem -- it spit them out of the heads. The aluminum heads had three or four threads that tried to hold the steel plug. We remember how that worked out and it took some six years to develop this solution.
Ford just dared these new improved long-snouted plugs blow out. Oh no. They were in to stay. They were probably tested fairly well, but it's the combination of mileage, carbon buildup and carbon aging along with corrosion that makes these near-impossible to remove.
Another six or so years go by before Ford makes yet another improvement to solve that problem.
I believe most engineers do their work in good faith. They try their best to test their designs and to anticipate problems. Often they suffer from the "designers optimism" and underestimate the shortcomings of their work. Other times, the shortcomings are compromises dictated by economics. Sometimes the shortcomings just aren't apparent at testing or turn out to be more severe than expected. SImetimes they are known but ignored by an incompetent management.
Environments, materials and suppliers vary. These engines were designed to run on unleaded gasoline, later ethanol blends, with additional impurities were introduced into them. The engines work in sub-zero and torrid climates, and testing can't simulate every possible environment.
Then once a design is tested, modified, agreed on by hundreds of decision-makers from all works of corporate management, millions and often billions are invested in its tooling.
I'm sure the board-room crisis meeting is a regularly scheduled event. "Just how bad's the problem??" "... How many claims do we anticipate over the next three years?" "What will the warranty work cost us?" "What's the cost of retooling".
The job of designing, testing and manufacturing isn't an easy one. Correcting runaway shortcomings discovered late in the game is even harder.... Every engineer knows that drill too well.
drokmofo
southern az
I was having the same issue w my 07 Limited. I did a transmission fluid and filter change 1st. Didn't really make a difference. I got the replacement plugs and the Lisle tool in case I broke any. Was really dreading if I broke 1. Took it very easy and deliberate when removing old plugs. Used a 1/2" drive breaker bar and torqued slowly off. None broke. Driver's side rear was not very tight. Maybe that was my misfire. After the plug change it has been running fine as far as that goes. Will do the COPs sometime soon. Now I need to replace radiator.
Ps4acc88
Ps4acc88
Dallas, TX
Update, got p0300 code, multiple misfire, so at least have a code now. Also, what should battery voltage be? Mine is 11.9v when key is turned to the on position(engine not running) and 12.9v when idling.
Misfire- I'm hoping the new plugs and cops fix it, I just replaced fuel pump last year so I doubt its fuel pump.
Possible low voltage- hope its battery, replaced the alternator last year
1955moose
Battery voltage needs to be at 12.6 engine off, 13.8 to 15.2 running. 14.2-14.5 is the normal. With multiple misfires, you start with secondary ignition, IE, spark plugs, coil boots/ possible coils, and go from there. These motors are very susceptible to misfires, especially if coils get wet. The p300 code is a multiple cylinder jumpy misfire. Common things are weak fuel pump, egr malfunctioning, a vacuum leak, or an internal engine issue. You might want to do a physical compression test with gauge, when plugs are replaced/removed. Last thing you want to do is chase your tail, if your problems inside!
theoldwizard1
SE MI
1st question) would you guys/gals agree that the spark plugs and coils might be the culprit? (No check engine light but I read many post where people said they had coil/plug problems with no check engine light.
It is highly likely !
"Better" scan tools can read "live" data and "pending" error codes. If you know how to use these features you can actually watch the misfire counter on each individual cylinder.
I'm betting the plugs were changed once already, if not they are overdue. Plugs are cheap on Amazon. Stick with GENUINE Motorcraft coils. These are NOT cheap, so knowing which cylinder(s) is the culprit is a good idea.
The "official" method of spark plug removal is a pain. Most professional mechanics do it on a hot engine and use an impact wrench. This method has had great success. Do you side, restart the car, bring it back up to temp and do the other side.
theoldwizard1
SE MI
Not on "modern" cars ! The voltages that the OP posted ARE ACCEPTABLE !
The ECM controls the voltage and it is kept low to prolong battery life and minimize the power lost to the alternator.
stilbo
Indiana
If there is a definite misfire your ecu will throw a code and your cel will light. At that point you should read the code and if it is indeed a cylinder/plug misfire the code will designate the specific cylinder/plug that is misfiring.
Beats replacement of everything except what’s bad.. and: Use Autolite Double Platinum plugs.
theoldwizard1
SE MI
NOT TRUE ! There is a specific criteria for turning on the CEL and it depends on other factors. Also, the criteria has changed (made more stringent) in later years.
BlueStangGT
Oklahoma
Since you’re in Dallas there’s tons of shops to choose from. I’ll bet you’ll find one that’s done this procedure within 3 phone calls. Make sure they’ll follow the Ford TSB instructions and will take responsibility for any mistakes. I’d started the process on mine with a Seafoam treatment before I got cold feet on completing the job. I’d already bought the plugs and even picked up a can of the actual recommended Motorcraft carb cleaner. I ended up negotiating a deal with a local shop to do the rest of it.
drokmofo
southern az
I would only use motorcraft plugs. SP546 replaced the dumb 2 piece 518. If u order on Amazon.com make sure u are getting the sp546.
kenf
Montreal Quebec
I'm having issues with my truck, when pressing on the gas at times it jerks. If I let off, or if I press on it hard it goes away. I have taken it to a couple of shops and all they do is run a scan but nothing comes up, they push back on messing with it until the computer registers an issue. Reading post and watching some videos, I think it might be spark plugs/coil packs. I was planning on replacing them as I'm sure they are way past due (bought truck with 120k) it's now at 148k so even if it's not the issue they need to be replaced.
2) my truck was made Feb of 2007, I read they stopped using the 2 piece plugs in 07 and some people with 07s dont have the plug breaking issues, is this false?
2007 expedition
4wd
148k miles
The fuel pump was replaced last year along with fuel filter
kenf
Montreal Quebec
Hi, Have a 2007 built in Oct 2007. The truck did come with the 2-piece plug. Got to 110000 kms or 65K miles. Decided to change out plugs as i knew the 2 piece where an issue. Went to a friends garage and 4 out of 8 plugs broke. Fortunately the garage had a Ford plug removal tool and also experience on Fords and the 4 plug bottoms were removed. If you plan on keeping the truck then go for the plugs first as mine was also showing Cat converter issues first, changed the sensors out same problem. The fix was the plugs. Another idea is to try and use a penetrating oil for a couple of days prior to trying to get them out.
Good luck
theoldwizard1
SE MI
Like I said ...
The "official" method of spark plug removal is a pain. Most professional mechanics do it on a hot engine and use an impact wrench. This method has had great success. Do one side, restart the car, bring it back up to temp and then do the other side.
Arni Atlason
I had similar issue when I bought my expedition 2007 model 137.000 miles.
When pushed pedal hard under load it did misfire.
Took it to dealer he changed spark plugs and cap after that havent got misfire since.
Ps4acc88
Ps4acc88
Dallas, TX
Update:
Still no check engine light but I got p0300 code, random misfire. After more driving it gave p0301 code, cylinder 1 misfire. I had a feeling it was the plugs/coil packs all along after a lot of research, but updating constantly as this seems to be an issue for many. So I want those having issues to have detailed info. Ordered new cop & plugs. Should have them replaced by sometime next week. Will update after.
gixer2000
Retrofit or Bust
Massachusetts
Update:
Mode 6 that you posted from your scanner tells the entire story. Cylinder 1 is the worst but still some misfires on the rest
Ps4acc88
Ps4acc88
Dallas, TX
Right, and I want to document my experience because many out there swear you have to get a check engine light if it's the plugs or cop
gixer2000
Retrofit or Bust
Massachusetts
That blinking SES light guarantees it's a misfire but doesn't fault to give you a location. So I think most wait for the fault to show before taking action so they know where to start
