JohnSKepler
I've been driving Expeditions since 2000. Owned a '98XLT and an '04Eddie Bauer, both 2WD. Had great experiences with both. Loved 'em! We're moving to Northern Utah so I was wanting to pick up a 4x4. Found a 2014 Limited 4x4 with 95K for a good price. It is a one owner and had every service record back to new. Oil changes every 5K miles. All the regular service intervals. Everything. Owned by an elderly gentleman and his wife who drove it around visiting their grandkids, apparently. It's loaded and looks and drives like a new truck. I'm super pleased. I hope it is as reliable as my other ones. But, there's a few little things that need some help.
1) The intermittent wipers don't work. They work fine in normal mode, but when in intermittent they wipe once and that's it.
2) There's a tap right above my head. Sounds like something slightly sticky in the roof is barely touching sheet metal and it sticking and pulling away with the vibration. Not like it has adhesive, but like a piece of soft plastic touching and pulling away. It's annoying and right over my head. If I just barely push on the head liner aft of the sun roof or the trim around the sun roof it goes away. Thought about pulling the trim strip off at the back door and seeing if I could get a bead on what's doing it.
3) There's a weird, intermittent whine coming from the engine compartment. It only happens when it gets started from cold and it's cold outside. It is soft and low almost like a dog whine and cycles on for about two seconds then off then on then off... Stops when the engine warms up. Air (smog) pump or related valve? Serpentine belt? Fan clutch (does it have one?)? Definitely some kind of accessory cycling and making noise when cold. I can only hear it when idling. Start moving and it goes away. Not sure if that's because it's warming up or because it's moving.
Any ideas?
Oh, my '04 is for sale if anyone is interested. White Eddie Bauer in great condition. Still drives like a new one.
Any ideas?
