Need help on figuring out if my 2014 Expedition has Remote start
Ron1978
Ms
I recently bought a used 2014 limited that only came with 1 key. I asked was there anymore keys and he said no, the key I got has no button to crank the car remotely, so I pop the hood and see a decal that says it has a remote start installed. Does it come from factory with this sticker or is it a aftermarket ? I took a picture of the sticker under the hood and my Vin if anyone can advise me on this. The Ford dealership says the 2014 is only showing a 4 button remote , not a 5 button remote.
ManUpOrShutUp
Do you have a kill switch under the hood (on the side)? You can also check for the brain behind the steering column off to the left (mine is all the way behind the adjustable pedal switch).
Yupster Dog
Moderator
Try hitting the your (4 button key fob) lock button 3 times holding on the third time
Ron1978
Ron1978
Ms
I tried it yupster, didn't work
Ron1978
Ron1978
Ms
I found the book on it in glove box paper work, so now I need to find where to order the fob from. I read in book the can be programmed easily
Trainmaster
Old School Member
Rockaway Beach, NY
The system that goes with that book was made by Code Alarm, owned by Voxx Systems. It was the aftermarket remote start sold and installed by Ford dealers.
Two types of system were available and I think they both had the same manual. A two-way system reported back to the transmitter that the car had started, a one-way system did not.
You can find remotes on ebay, but you'll have to determine which system was installed. Look for a part number on the module which is tie-wrapped to the harness near the steering column.
Ron1978
Ron1978
Ms
Ok I will, thx everyone for the help
Hamfisted
Ft Lauderdale
It's pretty easy once you read the instructions. On page 6 it walks you through it. Hit the lock button on the FOB, then hit the KEY button within 3 seconds. The parking lights should flash and the truck will startup. If you want to shut it down just hold the KEY button down again and it'll shut off.
Ron1978
Ron1978
Ms
I ordered a mint used remote from EBay for $7.99
Got it today, put key in turned it to ON the press brake, found the valet button under dash, held it for 15 seconds and horn chirped, push the remote and it chirped again, it programmed now!!!! Thanks guys for the help on this issue.
