In chanel windo deflectors
fetasigma
Madisonville
I have the wade in chanel window deflectors and I am having problems with bounce back, anyone know the reset procedure for the window sensitivity on theese 2018 models?
Sent from my SM-G892A using Tapatalk
16plati
VA
My dad has this issue with his f350. It’s because the deflectors are too thick and the window thinks there is something in its way. As far as I know you either need to get a brand with thinner plastic or get the ones that attach to outside door panel. No way to alter sensitivity as it’s a safety feature
F
fetasigma
Madisonville
Had to pull them out, may end up with some stick ons or just may do without
Andy B
Redding, CT
Don't do it. Learn from my mistakes..... I tried some "micro thin" in channel deflectors. Had serious bounce back issues than they broke my driver's side regulator. Had to replace the regulator.
I went stick on and never looked back.
Tereza
Chicago
Same here. Just paid $145.00 to have the drivers window regulator replaced because of in-channel deflectors and was advised to remove ALL of them because the rest of the windows are starting to show issues. I bought these about 3 years ago thinking of a sleek look (didn’t like the stick-on versions which to me looked cheap), but makes sense now. The window channels can’t accommodate the thickness of the deflectors very well and remember almost forcing the windows to close upon installation. Best bet: go with the stick-one.
F
fetasigma
Madisonville
Yeah I already removed them and pulled them out in frustration, don't want to do damage so will get stick ons if I decide I can't live without them, I also noticed much more wind noise at speed with them in
mquick5
Buckeye Country
AVS works fine in my 2017.
No problems here?
Also have had them in my 05 Sub since like 2008, no issues, there as well.
Sent from my driveway using Tapatalk
16plati
VA
No problems here?
2018s+ have different safety sensors
mquick5
Buckeye Country
Are they still limited to the auto-up on the drivers window only? And if the new sensor is the issue, I'm surprised multiple company's still make the in channel visors for them. I remember when buying them for my 17 some said will not work with auto-up windows.
Sucks that they won't work on 18's plus, cause I don't like the looks of the others my uncle put the cheap ones on his 17 F150.
Sgt Darkness
East Tennessee
So my ‘18 should be fine to get the inside fit wind deflectors since the sensor is “less sensory” on the 18s and up?? Member mquick5 says they won’t work on 18s.....just trying to uncover the truth before I buy the deflectors.......
16plati
VA
Pardon the confusion. Apparently the new models have a more sensitive sensor and will pick up more things in its way on the way up this is why ppl are having issues on them as opposed to earlier models of the 3rd gen
Sgt Darkness
East Tennessee
Appreciate the good info....especially since I haven’t bought either yet....
