Engine sputtering with momentary Eng light flashing
Adam_MFE2004
Germany
Today, I was driving my 2007 Expedition XLT 4x4 and it started sputtering/whole truck shaking like it couldn't make up its mind on gear maybe? Then the engine light started flashing. Only flashed for a few seconds and before i could pull over it stopped. Any thoughts?
LRNAD90
Sounds like Ignition misfires. OBD Scanner should help you track it down to the bank, if not the cylinder. Plugs or Coils likely would seem like first place to start..
bobmbx
Was it the CEL or the wrench symbol that was flashing?
LRNAD90
CEL was flashing. Can the OBD sensor show me that info if the light is no longer on?
It should be stored for some number of drive cycles. Flashing usually indicates Misfires, but the Check Engine light 'usually' will remain on after the incident until so many drive cycles have passed without it reoccurring.
A
Adam_MFE2004
Germany
That is for the info. The light flashed for about 90secs then went away and hasn't come back. Then I just found out about the damn service bulletin about the crap design of the spark plugs. My engine is in that time frame. FML
Grover6
Calgary
mine did the same thing about 10 days ago. cylinder #2 was misfiring. changed all the plugs and repkaced the #2 ignition coil and all is good. New plugs were gapped at .030 and all the original ones were .038 - .040. Engine seems to run a little smoother, and no more stumbles.
